My MY2003 has only 21K on the clock, but it just turned 8 years old. I know that the belt should be replaced at 60K mi.
The belt looks fine...no cracks. Should it be replaced because of its age?
Cracks or signs of wear would make me replace it. But if it looks good and remains flexible then you likely have more life in it.
Thanks Loren!
We generally replace the serpentine belts whenever we are doing any work that requires releasing it, regardless of how the belt looks. On a mileage basis, we swap them out at around 30K miles, purely as a precautionary measure. The belt is cheap, usually less than $30 retail, and easy to replace. On the other hand, loosing it can strand you, or could end up costing you an engine. On an 8 year old car, I would definitely replace it. I would also suggest carrying the used belt in the boot as a spare, as a replacement can sometimes be hard to find quickly at 2AM...........
And don't forget at least a large enough crescent wrench (or wrench) to swap it out... not sure if the stock provided one in the toolkit goes to 24mm.
Edited by logray
