P1341 read by Durametric on a 2003
Hi Loren, Logray, and all,
I've searched but only found info for pre-2001 cars, which don't have VarioCam+. My CEL has NEVER been ON but Durametric retrieved P1341. Does this code mean the actuator or its connections are at fault? Mine is a 2003 Carrera 2 coupe manual.
Is this the actuator, which Porsche call Solenoid Hydraulic Valve?
1_2002_911-Solenoid.pdf
or this one, which Porsche call Vane Cell Adjuster?
1_2002_911-vane-cell-adjuster.pdf
If the former and it's failing, is it just a simple remove and replace? Or I need to remove the cam cover, re-time, and such?
Many thanks,
Ahsai
Edited by Ahsai
Manufacturer Controlled Ignition System Or Misfire, Are your coil packs cracked?
Um...Durametric said P1341 is camshaft adjustment though. All coil packs were replaced by dealer a few months ago. Car drives very smoothly and there is no CEL.
Thanks.
Many thanks,
Ahsai
Most probable is you have a VarioCam actuator on the way out, there was a recent poster with the exact same issue and it was tracked down to the actuator. On the down side, this can be a bit expensive if a dealer does it; I think his all in bill was around $6K. May be a good time to find a quality indy in your area.................
Edited by JFP in PA
He's got a 2003 JFP so the actuators just pull right out of the cam cover. No need to remove the engine or pull the cam cover off...
The solenoids/actuators themselves a few hundred bucks if I remember right and pretty simple unbolt bolt on procedure.
Must be time for new glasses; I misread the model year.................. :eek:
Thanks Logray and JFP. Yea, I saw this thread which LOgray also replied to. Good to know this solenoid is just remove and replace. I'll check the connection first and then go from there.
