Brake rotors question
Hi guys;
Winter is over so I did put back my 2003 Boxster 2.7 on the road. Prior to that I did check the rotors depth. Any body can confirm if I have to plan a change out in the near future: Here are my readings (electronic caliper):
Front: 23.4mm & 23.2mm
Rear: 19.7mm & 19.5mm
Thanks for your help.
Thierry
Brake disc thickness New
front 24mm
rear 20 mm
Brake discs Minimum thickness (after machining)
front 22.6 mm
rear 18.6 mm
Brake discs Wear Limit
front 22.0 mm
rear 18.0 mm
Thickness tolerance of the brake disc, max. 0.02 mm
Lateral runout of the brake disc, max. 0.03 mm
Lateral runout of the wheel hub, max. 0.03 mm
Lateral runout of the brake disc when installed max. 0.06 mm
Thanks Loren, so seing your numbers I'm at half way, so doing 2000 miles/year, I will be ok for a few years...
Thierry
"Theoretically" yes.
But I would still check them yearly.
And, one trip to track can put the equivalent of 5000 miles on the car.
  • 11 years later...
