I need part number of the fasteners that hold the trim piece (dark plastic going down bottom side of front door, on outside). You can see the trim when you open the front door, then look down on outside of door opening, where bottom of door meets the chassis of car. There is a small plastic piece, dark, which is heldby white plastic fasteners (inside of the trim). If you pull the trim and twist up a bit, you can see the fasteners (I need the part number for those white fasteners). See pic.
post-79141-0-62889100-1345680535_thumb.j
post-79141-0-67855500-1345680570_thumb.j
post-79141-0-15721700-1345680633_thumb.j
Edited by ciaka
Item 3 -- 955-559-547-00 Clip mount door sill rail (front and rear) -- US MSRP $0.69 each
You may also need 955-559-586-00 Grommet mount strip door seal (front and rear) -- US MSRP $0.69 each
Loren, how about the p/n for items #5 and #6 on the diagram?
I believe those are what holds on the composite corner piece, correct?
I have a '08 Turbo w/Sport Package (option code 201 I believe, which covers the enlarges rear spoiler and sport rocker/sill covers)
(hope this is still on-topic for this thread as it's the same part group, but if it needs to be moved, so be it )
Item 5 is a clip that is used many places: 955-559-719-00 Clip -- US MSRP $0.49 each
Item 6 is a grommet 955-559-586-00 Grommet -- US MSRP $0.72 each
I go two years or so without posting or contributing anything and Loren still replies to my question within a few hours!
We don't deserve such dedication ,
Thanks man!
Can anyone tell me what the difference is between 6 and 9?  Are these grommets needed in order for 3 to hold snugly in place?
They are the same part number.
32 total used per one car - mainly as mounting for door seals, and fenders.
It looks like these grommets are what I need for the trim to "snap" into place.  Right now, the body of the car does not have the grommets. The diamond shaped hole where #3 would normally snap in is currently too big.
