Cooling fan issue
If you put power to the terminals on the fan itself, the fan should work. If it does work, the you most likely have a broken electrical connection somewhere between the battery and the fan. If the fan doesn't run with power applied directly to it, then the fan motor is the likely culprit and the electrical circuit is probably ok.
