Upgrading from Anologue - Digital TV ?
Hi everyone i have 2006 Turbo S and i want to upgrade the now obsolete Anolgue Tuner to a digital Tuner what do i need and is there anyone that has done this ?
is it as simple as just swapping to tuner ?
also i have found this ECU UNIT FOR A TV KOMBI TUNER  removed from a cayenne would it be compatable
PART NUMBER ON UNIT: 7L5919148A
DONOR VEHICLE  VIN: **WP0ZZZ99ZES160170**
Regards paul
I had the same question with my cayenne. It has the OEM analogue tuner installed, but now they have moved over to Digital in my country...as far as I found there is no simple way. You can try and install a third party digital tuner, but that will require pulling the IR eye somewhere in the dash for the separate digital tuner remote to work.
In the end I decided not to deal with it, the PCM screen is too small anyway to watch TV.
Thank you for the replies no  unfortunatley  no uk specific cayenne forums due to the limited numbers that this car was produced in the problem i have is the sound system is all bose with a analogue tv tuner i dont want to lose the bose sound i just wanted to swap the analogue tuner for a digital one that gadget on the connects site looks interesting i will delve further
thanks guys
