Can someone give us a run-down on how the intake distribution and tuning flaps are controlled on an S model?
- What generates the vacuum? (tandem pump?)
- How are the vacuum lines routed?
- Is there an accumulator?
- What actually controls the individual vacuum to the flap valves?
Bonus question: How can you tell if the distribution valve is being actuated?
Jay.
'06 987S.
That 2005 book is a great source of info!!  Wow!  Happy to contribute, but now I'm not getting much work done today!
  • 8 years later...
4 hours ago, Jayrasheed said:
Any chance you can post the tuning flap rpm ranges and function
I am sure that the tuning flap is controlled by the DME based a number of sensor readings.
The article above lists the rpm ranges for base and S engines in the 987.
