Life of LNE IMS retrofit bearing
For peace of mind I had the LNE retrofit bearing installing at around 35k miles.
Single row, LN 106 08-2, on the 2003 C4S.
Is there a recommendation about when, if ever, to do another prophylactic LNE retrofit?
Thanks. j
The numbers bandied around fortunately have grown somewhat with experience; current numbers are around 50K miles for the original single row bearing: http://imsretrofit.com/service-intervals/; while the newer "Pro" version for the single row engines is at 75K.
Why not do Raby's "The Solution" and be done with it once and for all?
Purely a cost & time horizon scenario, the Solution, while permanent, costs nearly $1K more for parts compared to either the old style single row or the newer Pro, and requires a bit more labor to install; and some people are simply not seeing themselves owning the car long enough to benefit.
Hi all, havent posted much on here, just curiously when did the PRO come out? I had an LN single row installed a number of months ago
About 18 months ago or so.  A lot of installers are not pushing it because they would need to acquire the Faultless installation tool to do the Pro, which costs around $750 for the tools.  There is really nothing wrong with the bearing you have, it is just that the Pro is believed to be even stronger.
Thanks for that, yeah especially being in Australia everything is 3x the price too!
I actually went back and read the box my LN Bearing came in and mine is the Pro pt. number LN 106 08-2.2 which is great news :D im not a big fan of the external feeding line of the solution even if it is a better product IMO.
There is nothing really wrong with the external oil line, it is incredibly durable braided stainless and tucked up out of harms way.
I agree its an excellent solution I just like the internal bearing, even better that its the pro as well. If the shop had offered the solution I would have considered it, unfortunately they didnt. Luckily my bearing was perfect and showed no signs of wear or play.
Just on this LN also recommend a year/mile replacement.  I.e. 75k or 4 years? Does the years hold any merit or should the miles be the primary focus for replacement? I was thinking about getting the solution next replacement.
Edited by dan189
I would think that the mileage is the more important number.  One of the largest strengths of the Solution is that it is permanent, which is a great point at resale.
