I reinstalled my instrument cluster on a MY 2003 996 cab. Now, all the failure indicators are on, fuel, oil, windshield fluid, and so on.
there is also no outside air temp. It seems that every systems has failed. When the fuel warning comes on the message says return to workshop.
any ideas what is wrong?
Are all the plugs fully engaged? You can pull fuse B1 for a few seconds and reinstall it and seee if that helps.
