New owner of 06 C4S. No temporary tire like my 01. Owner's manual and web search produces info about a can of tire sealant. After lots of looking I have failed to find the sealant or even a place where it could be stored. Being a 4 the common cubbies in the frunk are limited to one hatch, which houses the brake reservoir. Do I have a can of tire sealant and, if so, where did Porsche hide it? Thanks.
Jager:
Thanks a lot for your help. The sealant was right where you said it would be, and unopened. Do you think it is still viable after 12 years? A little more probing led me to the air pump under the floor carpet. Guess you need to have an empty frunk if you are going to have a flat! I also found a small folding mirror on a rod. I have no idea what that is for.
I have read some discussion about adding a spare tire and jack. I will consider that since I bought the car with the intention of doing some travel. I have a jack and tools in my 01 Boxster but I am not sure that spare tire will fit or provide enough support, especially in back. Maybe one of the expandable spares is a better idea?
Wish I could also add a dip stick!
John
My spare is the expandable type. It fits in the back seat with the bottom cushion removed. You can use the jack from your Boxster but make sure you have a proper socket for removing the wheel bolts.
As for the sealant, it's probably a good idea to replace with new. I didn't bother since I carry the spare.
Also, as White987s mentions above, it's a good idea to carry a plug kit when taking trips.
