Any one made a conversion to boxster 2.5 1999 swapping to a 3.2 2001
2 hours ago, twanny said:
Hi what did you do to the ecu and I used a 3.4 throttle body
You are going to need to use the 7.2 DME for the 3.2 engine, which may also require you switch to a later dash cluster as well, as the 2001 was already using CAN Bus technology.
25 minutes ago, twanny said:
So what is your recommendation to do
thanks both of you
The swap you are attempting is complicated; your 1999 car has a mechanical throttle, the 3.2 is an electronic throttle, the 3.2 uses different sensors and sensor communication protocols, if you have the factory alarm in the 99, it will not recognize the 7.2 DME, etc.  You will need the 7.2 DME, the entire wiring harness from a 3.2 donor car, the throttle pedal assembly, and you will be doing some creative wiring to tie it all together.  Your cooling system hard lines from the engine to the front of the car are a different size than the 3.2 uses, so you will need to either fabricate adaptors, or source the 3.2 hard lines, it also need the addition of the third forward radiator. Then you will need access to either a factory PST II or PIWIS computer to get your car to recognize the DME and visa versa.
It is all doable, but it is also a lot of work.  Good luck.
4 minutes ago, twanny said:
This is what he told me
You should use the ECU for the 1999 Carrera engine, not the one you have.
The 1999 996 Carrara would carry a 5.2.2 DME, not a 7.2.  A 2000 would carry the 7.2 DME, but again would be subject to the issues mentioned earlier.  You cannot simply swap DME's.
Am using a 3.4 throttle body it’s not machanical
