2000 996 coupe 6 speeds: door lock stopped working
There is a pin shaft on the back side of the key cylinder that can break or fall off.  You will have to remove the door card and access the back of the door handle to check it.  Here is a diagram of the door handle and key cylinder.  You can see the shaft on the back of the key cylinder.
WWW.AUTOATLANTA.COM
Edited by DBJoe996
WWW.AUTOATLANTA.COM
Thanks. I will remove the door panel and have a look at that pin shaft.
