1000 miles from my home (and tools) my 2011 Cayenne turbo misbehaves.
Headlights quit, instruments and all controls, including MFD and suspension controls go dark, while wipers start. I can't turn them off.
Engine continues fine.
Then, it all comes back. We repeat this several times as we drive through town. One time a check engine light came on, though it didn't repeat. Preset memory wasn't lost.
Research points to a ground problem. I did access the battery after an incident on the last trip traced to a bad connection on the right rear shock, which gave the the chassis system failure warning.
Anyway, no problems for 1000 miles until now. Research points to a ground problem. I have no tools to check battery connections, though I specifically recall tightening the connections.
So, any other ground points I should check, requiring no tools?
Made it home without further trouble. When we stopped overnight in downtown Lincoln, a check engine light popped up.
There were no indications of poor running, and it disappeared after one gas stop.
I did notice every time the display died, the voltage was in the mid-thirteens. Most of the way back today, some 700 miles, it stayed around 14.7, and there were no problems.
The battery is one year old, and I just had it tested two weeks ago by Interstate for another issue.
Could this be an alternator or regulator issue?
I should add, the alternator was tested as well.
Edited by JE 17
Checked battery ground at the terminal, and just for good measure, gave it a Deoxit dose. I haven't driven it a lot since, so I don't know if that was helpful. The terminal was not loose, though.
I will try to find the other end when I am able to put it in the air on my hoist.
Try running voltage drop test across both primary battery cables, Porsche has had problems with these cables developing internal corrosion that cannot be seen but causes all sorts of issues.
That seems like a good suggestion. I got the warning signs again last night; "headlight control" and "stop/start disabled," yet it didn't lose the MFD or instruments.
Curiously, the voltage was reading in the mid-mid-thirteens, which is when the problem usually occurs. If it's up in the 14s, there is no dropout.
I'll try to do this, but it may be tough to accomplish as I'm about to move 1000 miles!
