  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi loren, I lost my radio code also. thanks in advance.
cdr 220
2000 boxster
becker 1
4462
X5031703
48/98
Try 8507
or
8505
Thanks for fast reply Loren.
8505 work. much appreciated. thanks
Hi Loren,
Battery became disconnected and now I need radio code for CR-220 in a 2002 911 coupe. Would really appreciate if you can help.
Type 4362
Ser # 15000588
Hi Loren,
Type 4362
Ser # 15000588
Try 4193
or
4191
Hi Loren,
Type 4362
Ser # 15000588
Try 4193
or
4191
Thanks Loren - 4193 worked like a charm.
I am new here and not sure how to post within a specific topic. I need a radio code if someone could help it would be great!
1998 Boxster
5sp
CDR-210
V5017313
This is a U.S. Spec car, is there more information needed? If so please let me know
I think the CDR 210 is type BE 2282? Not sure though.
1998 Boxster
5sp
CDR-210
V5017313
Try 8846
or
8844
1998 Boxster
5sp
CDR-210
V5017313
Try 8846
or
8844
Neither one worked, I guess I'm at the mercy of the dealer?
1998 Boxster
5sp
CDR-210
V5017313
Try 8846
or
8844
Thank you for your patience with a newbie! I had even read that already too and just forgot. Now I have to wait an hour to try it again
Hello,
Just purchased a Boxster S today. The radio keeps asking for radio code which I do have but is not working. Any help would be great.
Model: cdr220
Type: 4462
Serial: y5042924
Thanks...
Hello,
Model: cdr220
Type: 4462
Serial: y5042924
Thanks...
Try 0837
or
0835
Loren,
I just purchased a 1999 C2 and am loving it. Haven't even thought about the radio all week but I would like to activate without paying $44 to the dealer. The previous original owner did not have radio manual or code card. I appreciate your help!
On my CR-210
V5008321
3297
Try 9224
or
9222
Unfortunately neither worked. Thanks for your help nevertheless.
Hello,
Model: cdr220
Type: 4462
Serial: y5042924
Thanks...
Try 0837
or
0835
Perfect!!! Thanks!!!!!
Hi.
Any chance of a radio code for my car, which I failed to notice was not included in the documentation when I bought it 6 months ago.
Bekker 1
Type 4467
S/N 15047096
24/99
Many thanks
Stu
my2000 C2 Tip
hi loren
please help me with lost radio code on the following unit this forum is really helpful found so much useful info here from changing oil on tip to other issues.
Type cdr 22
Model no: BE 4467
Serial No: X5018292
many thanks in advance
regards
Zak
Hi.
Bekker 1
Type 4467
S/N 15047096
24/99
Many thanks
Stu
my2000 C2 Tip
Try 5541
or
5539
hi loren
Type cdr 22
Model no: BE 4467
Serial No: X5018292
regards
Zak
Try 5408
or
5406
Loren,
On my CR-210
V5008321
3297
Try 9224
or
9222
Loren,
Just FYI, it ended up being 9324. Thanks for your time and effort.
Hi.
Bekker 1
Type 4467
S/N 15047096
24/99
Many thanks
Stu
my2000 C2 Tip
tu
Try 5541
or
5539
Thanks for the quick reply Loren. Unfortunately the codes did not work, and I tried the alternate digits either side as well as per your earlier suggestion. Back to the drawing board for me I guess.
Regards
S
I am the third owner of my car and I have 99% of the paperwork for my car but No Radio code :( SO Had some work done on my car this winter, installed a LWF, new RS clutch and replaced the battery and bingo I need a radio code--
Here are all my specs
1997 US
993 Carrera 2
CDR-210 with 6 cdchanger
(These are the readouts I got from the radio the hold 0 + 8 )
PR-Vers R 2896
Serial # v5010439
Thanks for your help!!!!!
Try 5016
or
5014
Got it , it was 5018-- Thanks for your help
Edited by marcuszane
I am also in need of a radio code for my 2002 boxster.
The radio info is:
Becker 1
model 4462
S/N 15003846
Thanks for the help!
Brian
Try 6439
or
6437
