  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Loren,
after typing this in, the screen blinks the first number ("2") -- I tried the following codes and this happens every time:
2535
2537
2539
2541
Is there perhaps something I need to press AFTER selecting the 4digit code?
Thanks for the quick reply!! I am driving 4hrs to Mid Ohio from Cincy in 2 days and hope to have a radio on that boring drive sad.gif
Please help my 993....Need code for Becker CR210.
Serial# T5001759
Thanks!!
Try 2539
or
2537
Loren,
let me know if you've any other ideas... btw my radio model # is R2095
Loren,
2535
2537
2539
2541
Thanks for the quick reply!! I am driving 4hrs to Mid Ohio from Cincy in 2 days and hope to have a radio on that boring drive :(
Serial# T5001759
Thanks!!
Try 2539
or
2537
Just the 4 digits - if it works then the radio comes on.
I hope this is the correct place to ask for the code
Model CDR 220
Serial number YSO34443
Try 1208
or
1206
Wrong code maybe its not a SO its
Y5034443, maybe thats why its not working
Tried both and none worked, also try 1207 and 1209
Model CDR 220
Try 1208
or
1206
Tried both and none worked, also try 1207 and 1209,
also tried 1201, 1202. 1203
Loren,
2535
2537
2539
2541
Serial# T5001759
Thanks!!
Try 2539
or
2537
Like I said those don't work unfortunately....Any other ideas Loren?
I just replaced the battery in my 1999 Boxster and need the radio code.
Model 4462
48/98
Serial #W5005855
Any help would be appreciated
Mary
Model 4462
48/98
Serial #W5005855
Mary
I tried 3051 and it told me to wait but then asked for the code again. The second code 3049 didn't work at all.
Model 4462
48/98
Serial #W5005855
Mary
PLEASE read the FAQ.
Another lost radio code:
1998 911 Carrera (993)
Model: CDR 210
pr vers: R 1996
Serial #: V5005469
Thank you very much,
E. Doheny
Hi Loren,please help
I got a 986 1998 US with CDR-210,with no code and looked into DME, with PST2-no code.
Serial number W5018983
I couldnt find a model nr.,
found on radio-2282B50W5018983,if helps.
others are damadged.
I read the faq,but it wont come out of the radio(model nr.)
part nr. on radio starts with 993.???others damadged
Thank you anyway
Thank you anyway
Try 7593
or
7591
Model 4462
48/98
Serial #W5005855
Mary
Hi Loren,
Thank you for all your help 3052 did the trick..........I got to enjoy listening to my radio today driving to work.
Mary
Hi Loren,
I've had my 2001 S model for a year and a half. The dealer I got it from apparently "lost" the owner's manuals and all. My radio is Becker1, type 4462, serial 15063141. Can you please help ?
Hi
I have same problem - battery disconnect whilst getting a new clutch, and no radio code
Becker CDR 220
Model Type 4462
Serial No. WS008932
Loren
Hope you can help with this one, let me know if you need further information:
Radio is Porsche CR-1 from a 1994 968.
Serial Number is POCR-1P1117624 V31117624B
Thanks In Advance
Steve
Loren
Thanks In Advance
Steve
Sorry, can't help you.
The program only supports CR-210,CR-220, CDR-220.
Hi
Becker CDR 220
Model Type 4462
Serial No. WS008932
Try 3601
or
3599
thanks - turned out to be 3602
