Hello, I'm adding a reply for a rainy day, of course.
However, It seems that when I change battery, the code request would pop up anyway.
Here is the information regarding my car & audio.
1. About Vehecle
(1) MODEL / YR : 986 / 97
(2) ENGINE : BOXSTER 2.5
(3) SHIFT : 5 SPEED MANUAL
(4) INTERIOR : YELLOW
(5) FROM : UNKNOWN, LHD
2. About Audio
(1) MODEL : CDR-220 BECKER 1
(2) TYPE : 7600
(3) SERIEL : 15003313
(4) ? : 38/01
(5) GAL : 00
(6) CD : CDP2081
Thanks in advance.
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
1. About Vehecle
2. About Audio
(2) TYPE : 7600
(4) ? : 38/01
(5) GAL : 00
(6) CD : CDP2081
Thanks in advance.
Try 2687
Thank you. If it doesn't work, I'll try 2685, 2689 and so on as U told to us.
I hope to check the number if it's right, but my audio is just working fine so far.
I really appreciate your help, and U take care. Bye now!
How did you obtain the serial number? From the method in the Lost Radio Code FAQ? If not, then you likely have the wrong serial number.
Hi Loren, sorry for requesting information in the improper fashion earlier.
My Becker1 CDR 220 type 4462 is locked
the serial # is 15086590 thank you for your help
Try 6590
Changed out the battery, anyway my serial # is X5024488 came up pretty easily with the instructions given, Thanks
Tom
Hi Loren,
my battery has just died and i need a code for my radio.
Can you please help me?!
Thanks a lot in advance ;)
CDR-220
Type: 4362
Ser: w5010420
Hi Loren,
CDR-220
Type: 4362
Ser: w5010420
Try 4876 ...................
Hello. I could sure use your help. I changed the battery in my 2000 Boxster S and lost the battery code.
Becker 1
Type 4462
Ser: Y5037557
CDP2081
24/99
Thanks so much, I'm a musician and lost without my car's stereo.
Becker 1
Type 4462
Ser: Y5037557
CDP2081
24/99
Try 5136
Becker 1
Type 4462
Ser: Y5037557
CDP2081
24/99
Try 5136
Totally worked, first time, no problems. Man, you are the absolute best! Fantastically quick response time, and total accuracy. The internet should have more like you! Thanks so much Loren!
Hi Loren,
I would really appreciate your help to get a code for my Becker CDR22
Type: 4467
S/N: 15055779
24/99
Thanks in Advance .... Paul
Hi Loren,
CDR-220
Type: 4362
Ser: w5010420
Thanks a lot !!! it worked :D thank you guys !
Not sure if you'll be able to help me. My battery needs to be replaced barely working for now but wont turn over the car. Car is MY2003 C4S with Bose and Nav, CD changer in the trunk.
when I push main and trip i get the following
PCM 3.0
System Software 3.0
Device type 6634
Serial number 35006278
when I disconnect will I require a code to get things going again?
if so can you help or is it a dealer only thing.
thanks again
PCM 3.0
System Software 3.0
Device type 6634
thanks again
PLEASE READ THE FAQ.
Lost Radio code FAQ
Hi Loren,
Type: 4467
S/N: 15055779
24/99
Is it possible to get the unlock code for my CDR22 from the serial number or will I have to pay the dealership? ....
Hi Loren,
Type: 4467
S/N: 15055779
24/99
Try 9859 ............
Model year
· Model/Engine Boxster S· Transmission type 6 speed
· Interior color blk
· Country specific information US
4462
15002990
CDP2081
24/99
