  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren,
I just purchase a replacement NAV CD for my PCM 1.0 in my 2002 996 TT. I have the code for the PCM, but need the code for the NAV drive.
its a Siemans unit, Porsche part number 996.642.122.0
MLFB: SWK76010
Serial # P0131007A742R
Hope you can help.
Ed
Hi Loren,
MLFB: SWK76010
Hope you can help.
Ed
Please read the Lost Radio Code FAQ.
Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC.
Radio Code Needed
:eek:
1999 Porsche 911 Carrera Cabriolet
Model# CR-220
Type# 4362
SN# X5017071
Please Help.
:drive:
Radio Code Needed
:eek:
Model# CR-220
Type# 4362
SN# X5017071
Please Help.
:drive:
Try 5343
Will do right after the WAIT goes away in an hour.
Thanks for the fast response Loren.
Stone
I have a 1997 boxter with a becker radio cdr 210.
pr-vers r 2896
sn v5008234
I bought it with the radio locked.
Can anyone help with a security code?
Try 1360
Thank you sooo much for the quick response.
I will try it when the wife gets back with the boxter.
Thanks again, you rock. It worked like a charm.
After having my battery replaced on my 996 2001, I need to enter the code for my radio CR-220.
serial # Y5023684
type 4362
24/99 (I don't know what is number meant.)
I hope one of you can help
Thank you so much
Paul
serial # Y5023684
type 4362
Thank you so much
Paul
Try 4391
That one worked fine.
I'll make sure I save it for 8 years from now, which is how long the old battery lasted!
