hello
can you help me also with my code
from a becker cr210
model : BE2182
serial number : T5000828
thanks !
Try 6876
Nice job thanks a lot !
greets !
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Another second owner without a code.
Type: 4362
s/n: 15000868
Try 0871
I did, and it worked.
Thanks.
Loren, I had posted a request late last night and have not seen a response from you yet, I wonder if it got missed with all of the requests today, don't mean to bother you at all, thanks again for this great service. thanks much. Phil
Becker cdr - 220
Serial Number: X5027842
MODEL NO. BE 4462
Loren, I too am in need of a radio code. The radio model is cdr220, serial number X5027842, MODEL NO. BE 4462 Thanks in advance. Much appreciated. Phil
Sorry, missed it somehow.
Try 8983
Hello. I have the usual request here. Thanks in advance.
CDR220
BE 4462
SN: X5036135
Try 9629
Thank you - that worked!
Loren, you did it again! Thank you so much, the code worked like a charm! All the best. Now I just need to figure out how to solder on a new male end to the antenna! thanks again. Phil
Loren, if you would please!
CDR 220
Type 4462
ser 15075702
24/99
thanks
Kevin
Try 4659
Thanks very much for quick reply. will try code this weekend..
Hi, I had to do some work on my passenger side window this weekend and disconnected the battery to ensure the side airbag wouldn't deploy. I now wish I hadn't due to the raio code I now need.
2002 996 Carerra 2 Cabriolet
CDR-220
Becker 1
Type: 4462
Serial: 15001455
Not sure what the 24/99 is.
Really appreciate the assistance!
CDR-220
Becker 1
Type: 4462
Serial: 15001455
Try 4956
CDR-220
Becker 1
Type: 4462
Serial: 15001455
Try 4956
THANK YOU SO MUCH =) It worked like a charm...
Hi I hope someone can help me. Same problem changed battery and no code.
CDR 220
Becker 1
Type 4462
Serial # 15976497
Hutchi
2001 Boxster
hy, i hope someone can help me. i just had a problem with my car and i disconnect the battery and now i lost the radio code. any help would be appriciated.
cdr 22
becker 1
type 4467
serial X5016104
thanks
cdr 22
becker 1
type 4467
serial X5016104
thanks
Try 9381
