  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
I'm converting my 2002 996 from gas to electric. I've removed all the legacy gas components and have started to power up the electric-only stuff. Today I had to replace the fuse in the back of the radio, now I need to find the code to unlock.
Here is the manufacture's data:
Becker
Type: 4462
15062753
24/99
Thanks for your help. You can read more about my project here:
http://kurtsprojects.blogspot.com/
Thanks again,
-Kurt
Becker
Type: 4462
15062753
24/99
Thanks again,
-Kurt
Try 2302
Thanks Loren! Worked like a charm. Now I can rock out while working on stuff inside the cockpit!
Thanks again!
-Kurt
Had to unplug the battery to change the starter, now the radio is looking for a key...
Becker CR-220
Model 4462
Serial X5037766
24/99
Becker CR-220
Model 4462
Serial X5037766
24/99
Try 4791
Works like a charm. Thanks.
thanks Loren..I'll give it a try tonight, if radio works then all i have left is the motor !! ha ha
two cracked cylinders, saving my sheckles for l and N and IMS retro.
would you go up in displacememnt or stick with 3.4 ? I'd really like to bump up a littel bit.maybe 3.6.
thoughts?
CD-2 I have several opportunities for the SN, as there are several numbers on it with different info:
Tag on bottom: CD-2; 54A90727F02-A
Tag on top: 50100 R; DP22A01 A; 8903-5JA
Stenciled stamp on chassis: 631228
Merci de avance!
Merci de avance!
Try 2387
or
12326
