  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Can I get a code for a Becker please?
Serial no. V5003067.
Thanks in advance.....
Ash.
Hi.
it's CR-21
Ash.
Ash.
Hi.
it's CR-21
Ash.
Try 9151
Hello got my 2000 Boxster S back on the road after a near 4 years rebuild. Code for my Becker CDR22 Type 4467 Seri X50 12458 would be much appreciated. Thanks.
Ash.
Hi.
it's CR-21
Ash.
Try 9151
Thanks for code, works fine.
Hello! Locked out on my 2000 boxster s
CR-2200
Type: BE 4466
Seri: Y5012375
47/98
Thanks in advance!
Edited by carterh232
1998 Boxster
CDR-210
Type: R3297?
Serial: W5021637
Strange thing though, I have the radio code card and the serial number matches the one shown on the radio display. I even called the Porsche dealer, same numbers, but the code doesn't work....there used to be that Java applet for this and when using that I remember using a different code. What do you come up with? Thank you so much!
1998 Boxster
CDR-210
Type: R3297?
Serial: W5021637
Try 4395
1998 Boxster
CDR-210
Type: R3297?
Serial: W5021637
Try 4395
Yep that's the one I have, and it didn't work. It just goes back to the first digit and keeps blinking.
I seem to remember the code that worked had something like 536X? Are there any other options?
1998 Boxster
CDR-210
Type: R3297?
Serial: W5021637
Try 4395
The only code for that serial number is 4395. So if that does not work and you are sure the serial is correct then you need to contact Becker North America.
Hello, I've lost the code to my 2000 Boxster S
CDR - 220
SERIAL NUMBER: Y5039049
Thank you for the help in advance
-Cheers Rob
Try 1707
Thanks for such a quick reply. I'm installing the rear speaker kit this weekend and will need the code then. I'll reply again and let you know if 6403 worked. Thanks again for the help ... Love reading this forum
Thanks again, the code worked and I'm now enjoying the back speaker addition :)
Need help with the following
CDr-220 serial number x5038006
Thank you
Thank you
This is the 3rd radio code you have requested a code for in the last two months - perhaps you should consider a donation to this site.
