  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
1 hour ago, MrRdStr said:
Model BE 2182 Serial V5008667
Thank you
You did not read the Lost Radio Code FAQ - read this first did you?
If you had you would have seen this: "Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
37 minutes ago, Olchame said:
Hi
Hope you can help, Cant find my code!
2001 Boxster
CD-220
Type 4462
24/97
Ser: 15075971
Try 2149
21 minutes ago, Olchame said:
Sorry that didn't work :(
any other possibilities??
Did you follow the procedure in the Lost Radio Code to get your correct serial number?
If not, then please do so and re-submit here.
2 hours ago, Olchame said:
Yes
here is a picture
Does that help?
It's a CDR220
but also says : CDP2081
It should be 2149.
If that does not work then the radio was likely repaired by a 3rd party and I can not help you then. Sorry.
Looking for radio code on my CD-R-220 model #be6625 serial# 15004827. I have a code of 0494 but it does not work. Please help
Try 3018
21 minutes ago, Ernest Roberts said:
Hi there disconnected my battery lost code to radio
Becker 1
4462
ser. 15005222
Try 4914
Becker 1
4462
ser. 15005222
thank you so much it worked
I already answered your request here (22 minutes after you posted):
Loren,
I have been searching all over the internet, and spoken with two different dealers who seem to have no clue as to how to get my recently replaced CDR-24/wBose (purchased on Ebay) to work beyond the Porsche Protect screen. I found your instructions online.
CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
Thanks for that!
I am still a little unsure as to what to tell them they need to do to reprogram the DME. They don't seem to know.  Do they need to program the new radios serial number into the DME?  Do they need a code?
If you know; can you give me a step by step overview of the reprograming, and the information that they'll need to reprogram the DME (and radio if needed.) I am taking the car in to get another key programmed next week, I'm hoping with the right information I can get this done at the same time. Thanks!
This is my first Porsche (absolutely loving it!) and while I eventually may upgrade the radio; for now, I'd like to get the CDR-24 working correctly.
