  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hello -  looking for the radio code for the following
CDR 220
BE 4462
serial # X5030057
thanks for your help.
CDR 220
BE 4462
serial # X5030057
Try 0456
Hello.
Could you please provide the radio code for CR-2200
SN 15000854
Thanks.
Thanks.
I reset the radio and got it to work by press and holding TP and S buttons simultaneously There’s a beep, enter the code and it worked. Display still doesn’t work.
Hi this is Jeff in south dakota and I recently purchased a 1997 Boxster and had to change the battery and so I need the code. I have a cr-210 and the serial number is
V5005446. Could you PLEASE help me with this!
Try 1054
Hi Guys
Just reinstalled the CDR23 into my 2003. It comes up with a message PROTECT. Any ideas? I don’t have the code in the booklets either - having read the whole lot twice.  Can anyone help please?
thanks
Graham
41 minutes ago, GrahamS2 said:
Hi Guys
thanks
Graham
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
In-laws Porsche Boxster sat for 4 years, I just got it up and running, major tune-up, new battery and that fun to get to alternator  and now the radio is locked?
Radio model.   CDR-210
PR-VERS.   R-2896
SERIAL #  V5008367
Fingers crossed, Thanks
Edited by Bruce Ward
Properly written now
PR-VERS.   R-2896
SERIAL #  V5008367
Try 9592
Hello.  Hoping you can help please with a radio code for:
Becker traffic pro
BE4721
25106036
Many thanks!
Edited by BTM529
Becker traffic pro
BE4721
25106036
Many thanks!
Try 35251
3 hours ago, Loren said:
Try 35251
Thank you so much -it worked! This must be a thankless task for you at times so much appreciation from Scotland to you 👍
1 hour ago, Unchained22 said:
Hi -
Would you be so kind as to provide the code for a CDR-210 (Becker BE 2282), serial number W5024276?
Thank you!
Try 9120
