45 minutes ago, Alex Grow said:
Ah no dice with that one. The only other possible numbers I can guess would be:
Type: 4462
SN: X5016639
I'll remove the radio and take a look at the sticker if those are incorrect. Thanks in advance btw.
Try 9576
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
4 hours ago, HaydenThaGr8 said:
Hi it would be great if you could help me find the code to my radio 🙂
Type: CR 2200
Model-No: BE 4466
Serial-No: X5011217
Try 2309
2 hours ago, Nicholas Hodge said:
Could you help with finding a code for this?
Type: CDR 220
Model: 4462
SN: X5026628
Try 9478
2 hours ago, Todd Moon said:
I had a dead batt in my 2000 Boxster, Can you help me out with my radio code Model 4462 Ser Y5043079
Try 1062
Hello,
Battery died and oddly enough the radio code card that came with the vehicle doesn't work on my CDR-220.
Model: 4462
Serial: X5020433
Thanks in advance!
2 hours ago, petenovotny said:
Hello,
Model: 4462
Serial: X5020433
Thanks in advance!
Try 4970
Hi, I had a dead batt in my 2002 911, Can you help me out with my radio code Model 4462 Serial X5025180
Thank you in advance,
Rod
Edited by Rodrigo Torres
Rod
Try 1094
Had to replace the battery and don't have the code
Type: CDR 220
Model: 4462
Serial: Y5041585
Thank you!
Type: CDR 220
Model: 4462
Serial: Y5041585
Thank you!
Try 0395
  • Thanks 1
