3 hours ago, Red 5 said:
would really appreciate some help with getting the radio code.
i have a Becker CDR 21
model number BE 2280
serial number V5012467
thank you
Try 4862
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
On 12/7/2023 at 8:25 AM, Loren said:
Try 9132
Hi Loren. So, my radio says "wait". I disconnected the battery. Once for 2 hrs, then again for overnight. I even pulled it out and unplugged it... Any tips? Also, if I swap the radio for aftermarket while the stock one says wait, will it cause issues? E. G. Is the radio locked or does the lock come from the ECM?
Thanks for your help.
Clint
Clint
Somebody didn't read the  Lost Radio Code FAQ...
"I get a WAIT on the display - what do I do?
You have to wait at least 30 minutes before trying again."
Loren,
Sorry for the redundancy with a second post but I just found this topic thread for requesting help with radio codes after I sent a separate message to you earlier. Below is the information in my original post.
Thank you in advance for any help you can provide.
Hello,
I just replaced the battery in my 2001 996 cabriolet and I do not have the stereo code. Would you be able to help please?
CDR-220
Type: 4462
Serial #: Y5053833
Thank you!
7 hours ago, STS said:
Loren,
Hello,
CDR-220
Type: 4462
Serial #: Y5053833
Thank you!
Try 2752
17 hours ago, Loren said:
Try 2752
The code worked perfectly. Thanks so much for your quick and valuable help!
Hi - I would really appreciate some help unlocking the radio in my “new to me” Boxster:
I got the following info following the instructions in the FAQ:
I have a CDR-220
type: 4462
Ser no: 15062082
Thanks so much for the help!
I have a CDR-220
type: 4462
Ser no: 15062082
Try 0276
Good Day please could someone assist me with the radio code for my 996 911 turbo
seriel # -PO8030206591/04
MFLB: 5WK 78003 --E
becker seriel # 55150766
Edited by beegrobler
MFLB: 5WK 78003 --E
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Just now, Shanghai_todd said:
Loren.. Happy New Year, hope all is well.. appreciate your help for a code on the following :
1999 996
CDR-220
Serial number X5013849
Thanks..
Try 6464
1 hour ago, Jason Giachetti said:
Hello,
Good evening and happy new year. Was hoping anyone could help here. I need the code for my radio
CR 220
BE 4362
serial no w5002465
EC102
Thank you in advance,
Jason
Try 4846
Thank you
Hi Loren,
Code 9132 didn't work. It's there another code to try?
I appreciate the help.
Quote
On 12/7/2023 at 7:12 AM, CJChaps said:
Becker CDR 210
Type BE 2232
Serial # U5011529
2 hours ago, CJChaps said:
Hi Loren,
"The suggested number did not work - what do I do now?
Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
Hi Lauren.
I previously posted, and it looks like I had a number one off in the serial number. Can we try again please?
Becker CDR 210
Type BE 2232
Serial # U5011528
My apologies, I appreciate what you do.
Clint
34 minutes ago, CJChaps said:
Hi Lauren.
Becker CDR 210
Type BE 2232
Serial # U5011528
Clint
Try 9124
  • Thanks 1
