I've read through this whole thread (phew). I guess since I have an older Porsche CR-1 radio without the code I am out of luck?
Dan
'86 928S 5-spd w/LSD
'93 968 Tiptronic
Get me the serial number and we can give it a try...
I got two numbers from the back of the unit itself:
POCR-1R0821899
V40821899B
Dan
'93 968 Tiptronic
Do you know if it is a 4 digit code?
If so, try 0827
or
0825
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Dan
'93 968 Tiptronic
POCR-1R0821899
V40821899B
Dan
'93 968 Tiptronic
If so, try 0827
or
0825
Yes, I'm sure it's a 4-digit code since I've entered them before on other CR-1's. Unfortunately, with these radios you can only enter digits 1 - 6 so I would have no way of entering those codes. Thanks anyway :)
Dan
'93 968 Tiptronic
Dan
'93 968 Tiptronic
POCR-1R0821899
V40821899B
Dan
'93 968 Tiptronic
If so, try 0827
or
0825
Dan
'93 968 Tiptronic
I don't know if this will be of any help, but I do have a busted CR-1 here which I know the code to:
POCR-1P0114389
V30114389B
Code 1226
Could you use this as a cross-reference of sorts?
Dan
'93 968 Tiptronic
Dan
'93 968 Tiptronic
POCR-1R0821899
V40821899B
Dan
'93 968 Tiptronic
If so, try 0827
or
0825
Dan
'93 968 Tiptronic
POCR-1P0114389
V30114389B
Code 1226
Dan
'93 968 Tiptronic
Sorry... none of my decoders handle 6 digit results.
You can try here - although they do charge for the service.
http://www.car-audio-accessories.co.uk/por...radio-codes.php
Dan
'93 968 Tiptronic
POCR-1R0821899
V40821899B
Dan
'93 968 Tiptronic
If so, try 0827
or
0825
Dan
'93 968 Tiptronic
POCR-1P0114389
V30114389B
Code 1226
Dan
'93 968 Tiptronic
Er... what I meant was that the codes are 4-digit codes, but each digit can only range from 1 - 6 (since you enter the code using the preset buttons on the radio face, and there are only buttons 1 through 6). I'll check out that site, thanks.
Dan
'93 968 Tiptronic
Im not sure if I have missed this or not, but is there any way to bypass the "Wait"?
Thanks.
No, you must drive the car (it has been covered many several times in this thread).
Same situation as others...2001 Boxster
Becker 1
4462
y5048116
24/99
Thanks for your help in advance.
Try 5511
or
5509
Neither worked. Besides contacting Porsche or Becker, are there any other suggestions?
Becker 1
4462
y5048116
24/99
Try 5511
or
5509
All covered here before (if folks would just take the time to read).
You can try two digits up or down of the first number I gave you - that has worked for some.
If nothing works then you either need to contact your dealer or Becker. Last time I checked Becker charges $30 to look up up your code.
Hi Loren,
Same story here.... Just purchased the 986 2 months ago and disconnected the battery to charge it.....
Becker unit
CDR 220
4462
Ser- 15009520
Thanks very much! Dan
Hi Loren,
Becker unit
CDR 220
4462
Ser- 15009520
Try 7794
or
7792
Loren!~
I may finally be figuring out how to post on here!~ Sorry for the blond roots.. I bought our car a year ago, and just now realized that the battery replacement entails inputting the radio code, of which I never Got from the out of state dealer!~ [& it wasn't even a Porsche dealer either!]
anyway, I have READ the posts [!~~! :):) ], and Have gotten the S#, etc from the TP portion of the Becker radio I have, and Will try up or down 2 #'s from the code you [hopefully, Please Please!~!~] are able to find on my behalf?... I will be eternally grateful for any help/info you can provide... I believe the info You need from me is as follows:
Becker radio
CDR 220
4362
S# 15001795
24/99
2002 Boxster S
Thank you in advance for your time and efforts, my gosh, there are a LOT of people you must have been able to help on here!~
Happy Motoring,
Todd
Hi Lauren. My radio is locked. Can you help a brotha out?
Type: 4462
Serial: 15085371
24/99
1999 Porsche Boxster 2.5
My name is Loren.
Try 3274
or
3272
Loren,
I tried the codes and they didn't seem to work. I'll retry in the morning after the "WAIT" disappears again. I might have mistyped. Sorry about the name mispell. I noticed right after I posted it. I have a friend named "Lauren" as well, so my fingers are just used to typing it. Thank you again for your help.
Mike
Loren,
The two codes didn't work. Any other suggestions? Thanks again for your help.
Type: 4462
Serial: 15085371
24/99
My name is Loren.
Try 3274
or
3272
Loren,
Mike
Loren,
Please... it is all covered here before (if folks would just take the time to read).
Loren!~
Becker radio
CDR 220
4362
S# 15001795
24/99
2002 Boxster S
Happy Motoring,
Todd
Try 6411
or
6409
Loren!~
Becker radio
CDR 220
4362
S# 15001795
24/99
2002 Boxster S
Happy Motoring,
Todd
Try 6411
or
6409
Loren!~
TY for getting back to me so quickly... unfortunately neither the 6409 or 6411 worked?? Do I try 6407 or 6413? or?
Todd
Loren!~
Becker radio
CDR 220
4362
S# 15001795
24/99
2002 Boxster S
Happy Motoring,
Todd
Try 6411
or
6409
Loren!~
Todd
Yes you can try that - it has worked for a few folks. Just keep trying a two digit difference each time.
If all else fails you will need to contact a dealer or Becker.
Loren!~
Becker radio
CDR 220
4362
S# 15001795
24/99
2002 Boxster S
Happy Motoring,
Todd
Try 6411
or
6409
Loren!~
Todd
DARN, I "Have" to drive for another hour!~~! btw, the English web site mentioned for $18 for an instant code requires Internet Explorer as a browzer [ie, not this Apple!~]
Thanks again for all your help!~~!
Todd
Hi Loren,
Would appreciate a radio code for..
CDR 220
Becker 1
ser: 15061915
24 99
cdp2081
paul
Try 0955
or
0953
Thanks Loren
0957 worked
