  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Code needed for CDR220
Type: BE 6625
Serial: 15006014
Thank you !
This is a different radio than the one you requested in Feb 2009?
Yes Sir. I have purchased 2 used radios, this one already in hand, another one coming soon (don't have serial yet).
These are purchased from EBAY, I can point to the auction if you would like.
They are for 2 buddies of mine.
Klaus
Type: BE 6625
Serial: 15006014
Thank you !
Klaus
Try 1491
or
1489
Type: BE 6625
Serial: 15006014
Thank you !
Klaus
Try 1491
or
1489
Thank you Loren !
Second unit arrived today, CDR220, type BE 6625, Serial 25013769
This one was purchased from CANADA, don't know if this is a factor for you,
Thank you again !!
Klaus
Loren I tried the codes you gave me, they didn't work. Any other suggestions? The type is 4462, the serial # is y5047555.
Yes - READ the FAQ.
Hello Loren,
I am hoping on receiving your help for code of the following unit:
CDR220
Type BE6625
Serial 25013769
Thank you !!
Klaus
Hello Loren,
CDR220
Type BE6625
Serial 25013769
Thank you !!
Klaus
Try 8655
or
8653
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Hello Loren,
Unfortunately I have not yet been able to activate.
I have read your FAQ and I understand the odds of not being successful.
One point I noticed: Using the TP function the device type shows BE4462 (NOT 6625 as on outside label)
Would type 4462 yield a different code for Serial 25013769 ?
Thank you,
Klaus
Hello Loren,
CDR220
Type BE6625
Serial 25013769
Thank you !!
Klaus
Try 8655
or
8653
Hello Loren,
Thank you,
Klaus
No, the code is based on the serial number.
So if you gave me the correct serial number - then you have my best guess.
Hello Loren,
CDR220
Type BE6625
Serial 25013769
Thank you !!
Klaus
Try 8655
or
8653
Hello Loren,
Thank you,
Klaus
OK, I understand, Thank you for your help, I will keep trying some other combinations.
Klaus
