  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
I need a radio code for my 2000 996. The battery died... please help!
Becker 1 CR-220
type: 4362
s/n: X5019995
47/98
Thanks in advance and great forum.
Matt
Try 7499
or
7497
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Thanks, but unfortunately, they did not work. I will try the # +2 as you recommend, but gotta wait the 1 hour now.
Thanks anyway,
Matt
Loren,
I just bought my 2002 Boxster S and it didn't come with the radio code. Any help is very much appeciated!
cdr-220
Becker 1
model 4462
serial 25013325
thanks
Matt
Try 2782
or
2780
Loren,
Thanks for getting me the codes. Unfortunately I tried the numbers and the -/+ 2 as suggested in the FAQ without any luck! Still very happy to have found RennTech and learning how to take care of my car.
Thanks again,
Matt
Loren, I know from the previous posts that the CDR23 doesn't have a user settable code but my question is if I disconnect the battery for any reason, say to change it out will the radio work when I reconnect the battery or do I need to take the car to a dealer?
Edited by Deepsix
No, not if the radio worked before.
The only time it should need to be re-programmed is if the radio is replaced with a different one.
I need my radio code, the one on the card doesn't seem to work (8302)
Can you look it up?
1999
C4
6 Speed
Black
USA
CDR-220
Type 4462
Serial W5003094
01/99
Can you look it up?
1999
C4
6 Speed
Black
USA
CDR-220
Type 4462
Serial W5003094
01/99
Try 0182
or
0180
Wow!
0182 worked like magic!
That is cool, and thanks for replying so quick!
I definitely owe you a beer or two
Aha - I see you can donate at the bottom - I'll do that - thanks so much!
BuddyK
Loren,
The code did not work. Do you have any other idea. I tried a couple of times. It just goes back to the **** sign on the display.
Loren,
PLEASE - read the FAQ.
How long do I have to wait before I can enter each of the 2 codes? It says wait but then after about 5 minutes goes to the **** screen.
I will try changing the code up 2 or down 2.
All answered in the FAQ...
please could you help, I have the same lost code problem in my 2001 boxster s. the radio says it is a becker 1, type 4367, serial no Y5023622. the car is right hand drive british version.
Can anyone supply me with the radio code for my
Becker CDR220
Type 4462
Serial # 25016763
Tim
ps: Admin, I hope this is in the right place now.
Newbie who has yet to figure out how to post.
Try 0311
or
0309
tried 0309, 0311 and 0307, non worked unfotunatly. The radio now says WAIT, I will leave it on for 1 hour and try 2 digits up and see if that works.
Hey Loren,
Can you help me out my radio code doesn't work.
1999
Carrera 3.4
6 Speed
Yellow
USA
CDR-210
R3297
Serial W5022338
01/99
Thank you so much in advance!
Gavin
