  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Good afternoon,
After a alternator change I have found out I dont have the code for the stereo :(
Becker 1
Y5016024
Could I bother you for the code?
Many thanks
Robin
Try 5157
Good afternoon,
Becker 1
Y5016024
Many thanks
Robin
Try 5157
1st time :) perfect
Many thanks
Hi, I hope you can help me on this.
CR-21
SN: T5000474
Thanks.
Try 8982
Code doesn't work. Any other code I should try?
Thanks.
Did you use the method in the Lost Radio Code FAQ to get the serial number? If not, then it is likely wrong (which will give you the wrong code).
Anyone still watching this topic? I have a 2002 Boxster base. The radio (CDR-220) works fine, but I'd like to attach an aux/iPod cable and the instructions say to disconnect the power to the head unit during installation. The menu reports serial number 25014726.
--scott
--scott
Please post your question in the appropriate forum - this thread is for Lost Radio codes only.
Please help with cdr220. Type 6624 Serial number according to "tp" button is 15000005. 24/99
Thank you
Edited by dakar
worked great, thank you.
Thank you
Try 1040
Hope you can help, need radio code for my 2002 Boxster. Becker Radio Serial # 25013393, CDP2081, Type 4462. Thanks in advance!
