  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Phil: Loren, I have a cdr 220, 2002 manufactured date , BE 6625, serial number 2501 4833 Do you have a code for this one? Thanks so much for your help. Phil
Loren:
Try 3076
Phil: Loren, worked great! Thank you so much for this service! All the best. Phil
Hi, just changed my battery with the trickle charger plugged in, but the radio is asking for a code...
CDR 220
Serial Number: Y5041185
Type: 4462
24/99
Many thanks for your help!
CDR 220
Type: 4462
24/99
Try 8458
Revered Experts,
I just bought a 99 Boxster, Battery was dead. Could I get the code for the CDR-220 model 4462 serial X5024801 ???
Thank you very much.
Revered Experts,
Try 2810
Revered Experts,
Try 2810
Outstanding! IT worked! Thanks again for your time!
we need a radio code for cr1 radio with radionr serial #POCR-1P0615337B. Owners manual states it is 3103 but there is no button marked with a "0". The only buttons with numbers are marked 1-6. Also the process of pressing the number "1" button 3 times and the number "3" appears does not work on this model. So this being the case, what number is used for the "0". Please help!!
From the Lost Radio FAQ
"Which radios can not have their unlock code recovered through serial number?
- CR1 - Alpine
- CDR-23/24 (or later) - Becker
- PCM (Porsche Communication Management) – Siemens & Becker"
Hi!
Please help with radio code with my Becker 2200
Type 4466
Serial 15020354
Alex
Philippines
Thanks Loren!!!
Works now, another question is that my box came from japan (89.9 to 73.3) and the frequencies are different, is there a way to convert it (88.3 to 107.9)?
Thanks again!
Hi!
Type 4466
Serial 15020354
Alex
Philippines
Thanks Loren!!!
Thanks again!
Page 27 of the (Radio) Owners Manual.
You can download a copy here
Hi
Another Norwegian with disconnected battery, and in need of some help:
When pushing the TP button for 10 seconds, it shows Becker 1, then 4467, and then serial number W5002188. When turning the knob again, it displays 01/99. On the manual it says CDR-220.
Hope you are able to help out.
B.Rgds.
Werner Hjelt
Hi
B.Rgds.
Werner Hjelt
Try 8292
