  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren, can you try mine? I have a Becker CDR 220. My radio serial is "Y 5035839".
Try 2924
Thanks! That worked!
HI,
I lost my prsche boxster 2000 radio code. I followed a few instructions online and managed to view the serial number:
Porsche boxster 2000
CDR-220 Becker 1
Serial number: W500281101 / 99
Type: 4362
Many thanks!!
HI,
CDR-220 Becker 1
Type: 4362
Many thanks!!
Try 4202
2nd owner of this 1996 Carrera 2, replaced the battery and don't have the radio code.
Becker CR 210
SN: 51001812
Thanks so much!
Edited by bykerboy
Hi thank you for your prompt response. The code is unfortunately working
I said boxster but its a porsche 911, my bad... With the same serial number:
W500281101/99 TYPE:4362
Thank you!
Thank you!
The radios are the same for Boxster, Carrera, and Turbo.
Did you follow the instructions in the Lost Radio Code FAQ to get your serial number?
Becker CR 210
SN: 51001812
Thanks so much!
Try 6548
That code did not work.
Becker CR 210
SN: 51001812
Thanks so much!
Try 6548
Hi Loren,
I did. Held TP down for 10 secs and rotated it until: W500281101/99 TYPE:4362 appeared.
If you did it per the procedure then it should work (and has for most all in the part).
If it is not working then I am sorry and you will need to to to your dealer/OPC.
Becker CR 210
SN: 51001812
Thanks so much!
Try 6548
Yes I did. That was the SN I supplied in my original request.
Does that SN not look correct?
SN: 51001812
Becker CR 210
SN: 51001812
Thanks so much!
Try 6548
SN: 51001812
Becker CR 210
SN: 51001812
Thanks so much!
Try 6548
SN: 51001812
I'm out of town for work the rest of the week. I will double check the SN when I get back in town.
Thanks for the assistance.
I had to disconnect the battery to replace the ignition switch and now my 1999 Boxster needs the code entered and I don't have it (pretty much the normal story).
Becker CR-210
R3297
SN: W5022855
Thanks very much for your help.
Becker CR-210
R3297
SN: W5022855
Try 6702
Becker CR-210
R3297
SN: W5022855
Try 6702
Unfortunately, that didn't work. I've tried numbers around that, but no luck. Will try some more numbers later.
Thanks for your effort.
