Hi Loren,
I bought a 01 Boxster and the previous owner can't find the radio code card and he didn't write it down in the maintenance manual.
I've got :
Becker
CDR-220
4462
S/N Y5053058
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren,
Similar story as everyone else. dead battery, cant find the radio code.
Becker CDR-220
Model # 4467
Serial # X5017136
49/98
Thanks For Helping
Try 9547
Ok so it worked. Thanks. but i have no sound.
Help
Hi Loren,
I've got :
Becker
CDR-220
4462
S/N Y5053058
Try 9079
Hi Loren,
Becker CDR-220
Model # 4467
Serial # X5017136
49/98
Thanks For Helping
Try 9547
Help
Please post other sound system issues in a new thread in the appropriate forum - this thread is for Lost Radio Codes ONLY.
Do you have an amp? If so, have you checked the fuse?
I also have a becker cdr 220 model #4462, serial # Y5046223 and I need a radio code for it too,... and does anyone know what size fuse it should use?
Keith Taylor 996 Cabriolet
Try 4732
I had to disconnect the battery to replace the ignition switch and now my 1999 Boxster needs the code entered and I don't have it (pretty much the normal story).
Becker CR-210
R3297
SN: W5022855
Thanks very much for your help.
Try 6702
Unfortunately, that didn't work. I've tried numbers around that, but no luck. Will try some more numbers later.
Thanks for your effort.
Did you follow the instructions in the Lost Radio Code FAQ to get your serial number?
I am trying figure out what CR-210 owners are doing - because I have gotten many codes correctly and all of sudden they seem to be wrong.
Yes, I followed the steps, but I can go through it again to make sure I didn't mistype anything.
Just had my car at the dealer and they got the code for me and it was the same one you gave. Do you know if there is a step that you need to do after you enter the code? Perhaps that would help other people having the same issue with the codes not working.
Becker CR-210
R3297
SN: W5022855
Try 6702
Sorry I do not have a CDR-210 to try this on. Perhaps someone else can help.
Hi everyone
would really appreciate it if someone could help me with obtaining a code for my replacement Becker BE4367 , serial number X5009216 .
Many thanks in advance
Steve
Hi everyone
Steve
Try 1026
Hi guys,
New to this forum.
i too am in need of my radio code
Becker 1
type 4362
ser X5013712
thank you very much
Hi guys,
New to this forum.
Becker 1
type 4362
ser X5013712
thank you very much
Try 8109
thank you i'll try that after i fix my horn. now that i put o rings the horn is just continuously on -_-
Hi I have a PCM1 in a 2002 3.2s which porsche do not have the current code (suspect a replacement not registered)
SN is PO815016367501
I put this into a code website who charged and the 2 codes 2104 & 1102 and they dont work - now have a 60min reset wait
any help would be much appreciated
thanks
thanks
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM?s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hi guys,
New to this forum.
Becker 1
type 4362
ser X5013712
thank you very much
Edited by jk944
