  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Loren,
Yes, I follow the instruction step by step and successfully retrieved the serial number without any problem. But the code is not correct.
Michael Ho
Did you try 3062
Hi Loren,
I hope all is well. I need your help with the code.
CR-220
TYPE 4362
S/N 15003843
I appreciate your help. Thanks
Sorry, in addition to my prev note, the type is 4462
SN is 15087191
thanks
Try 0702
Perfect. I am so thankful youve been on top of this thread for so long!
Yes Loren we tried this last year as well with no results...I did follow the directions and get Y5039185...I have a picture of it but can not seem to get it posted...
Loren,
Michael Ho
Did you try 3062
Loren,
You are the best. I try 3062 and the radio come back to live immediately. Thanks a bunch. Keep up your good work.
Michael Ho
Hi, wondering if someone can help me with retrieving my Becker Radio code on a 2001 Boxster
Its a CDR220 serial Y5052609
Much appreciated if someone can help…. much as I love the engine note, I could do with some music :)
Hi Loren;
I need your help with a radio code for my 2001 Boxster S.
Radio model is CR220
SN is Y5022909
Thank you very much,
Tom Binder
Walla Walla, WA
Try 0397
Hi Loren;
SN is Y5022909
Tom Binder
Walla Walla, WA
Hi Loren;
SN is Y5022909
Tom Binder
Walla Walla, WA
Try 0719
Hi Loren…. you my friend… are a genius…. first try with the code you gave me worked… can't thank you enough.. :)
Hi Loren,
I have the same problem with my Boxster.
Becker 1 type 4467 (CDR-22)
SER: 15055952 24/99
Hope you can help, thanks in advance!
Hi Loren,
SER: 15055952 24/99
Try 1097
Greetings Loren,
I have a CDR-220 but need the code. Here are the details:
Becker CDR-220
Model No. BE 4462
Serial No. Y5050161
Thanks in advance, your help is greatly appreciated!
Rich.
Greetings Loren,
Becker CDR-220
Model No. BE 4462
Serial No. Y5050161
Rich.
Try 8456
Thanks for the help, Loren. But no luck with that code.
Did you follow the procedure in the Lost Radio Code FAQ to obtain your correct serial number?
Certainly did. Perhaps the 5 is an S? I double checked the numbers and that's the only digit i'm ambiguous about.
Serial number: 1S007409
For that serial number it should be 3109. This works 99.997% of the time.
Sorry, try Becker North America.
