  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi there,replaced the started motor in my 986 and it locked my radio.
Model no.7820
Serial number.55088523
Many thanks
For 6 preset Traffic pro
try 61532
I Loren
I have a PCM1 Double Din unit and need a code please.
Serial Number is PO8150138956/01 (On the Siemens Label)
BECKER Label
Becker Type IDIS
Model No BE 2580
Ser No 25106799
Hope this helps. You are my last hope.
Many thanks.
Malc
I Loren
BECKER Label
Becker Type IDIS
Model No BE 2580
Ser No 25106799
Many thanks.
Malc
Please READ the Lost Radio code FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
hi loren,
would you help me retrieve the radio code for cdr-220
becker 1
type 4462
cd cdp2081
24/99
serial #15088534
many thanks, ray
hi loren,
becker 1
type 4462
cd cdp2081
24/99
serial #15088534
many thanks, ray
Try 1682
Hi, I had to change the battery on my 2000 Carrera4 and now need the radio code.  Owners manual is missing, here is my radio info.
Becker CR220
Model number BE4362
Serial number X5019297
Becker CR220
Model number BE4362
Try 5258
I replaced my battery on my 2002 porsche 911 turbo and now I need the radio code.
CDR-220
Becker 1
Type 4462
Serial number 25011027
Can anyone help me . I had to replace the battery in my 1999 boxster . And my radio tells me I need a code .there no code card in my manuel booklet . Can anyone find the code ? My radio is
becker 1
CDR 220
BE 4462
15062451
24/99
Edited by Sky1997w
becker 1
CDR 220
BE 4462
15062451
24/99
Try 4734
Hi Loren,
Thank you for still doing this after so many years!
Car's info 2001 911 C4
Becker CDR 220
type BE 4462
serial # 15088188
24/99
Will
Hi Loren,
Becker CDR 220
type BE 4462
serial # 15088188
24/99
Will
Try 9673
Hi Loren,
Becker CDR 220
type BE 4462
serial # 15088188
24/99
Will
Try 9673
Thank you!
Hi Loren,
Thanks for providing this valuable service to Porsche owners everywhere! My code has also been lost. Details are:
Model: Becker 1
Type: 4462
Ser #: Y5045599
Much appreciated.
Hi Loren,
Model: Becker 1
Type: 4462
Ser #: Y5045599
Much appreciated.
Try 9436
