Was working fine of course till the battery removal. Previous owner did not write it in the manual... Following your radio I.D. recovery procedure I've gotten the following: CDR 220  Type 4362  and serial # 15004832. Hope you can help. Thank you in advance. The radio code is the most important item for me at this time.
Try 3058
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Loren, First, thank you for the quick reply. Went to garage to put in code. Turned key on, radio power on, and get the same "wait" message. Now my question is this: does the half hour, or 1 hour internal radio timer begin while radio is powered on, or even if it is powered off? The reason i am being precise to this question is because 4 or 5 days ago when i tried a random (0000,1234) code i got the "wait" message. I turned the power off to the radio and have not had it on since. Last night based on your advice I powered radio on, wait message was still on the face, held TP button for 10 seconds and finally the wait went away and I was able to get you the radio i.d. So should i power it on during my driving around today and will the wait go away or is there another procedure i can follow to get rid of the wait and the code prompt to come on the radio dial?
Becker CDR-220
TP screens:
Becker 1
Type 4462
Seri 15006411
24/99 <-- what is this?
Gali 00 <-- what is this?
Aux OFF
CD CDP2081
Try 6989
Becker CDR-220
TP screens:
Becker 1
Type 4462
Seri 15006411
Aux OFF
CD CDP2081
Try 6989
Boom done!  Thanks!  Now to figure out how to program the presets....
Thanks Loren that code did work.
i have radio now.
I just need to find out why when i try to insert a cd it wont go in.
like it wont fit.
Thanks ahead.
Hey Loren,
I'm new to the boards and a car new to me.  It needs a radio code.  Becker CR 220.  Type 4362.  Ser # W5007674.
Can you assist?
Hey Loren,
Can you assist?
Try 9656
Hey Loren,
Can you assist?
Try 9656
Awesome. Worked like a charm.  Greatly appreciated!
2000 Boxster S
Becker CR-220
X5035677
Thank you!!
Try 0875
Perfect!  Thank you so much!  It's nice to have a radio again.
Got it! your code worked instantly!!! :jump:  Thank you!  :notworthy:
I guess I answered my own question from above on:   How do I get rid of the wait message
So here is a little help for the rest of your members having the same "wait" message.
Know that the radio must remain on for about an hour before the "wait" goes away and the stars show up to input your code.
By wait I mean driving and stopping, or sitting with key on: Radio still has to be on power.
I drove for a few weeks with the radio off, and every time I tried it on, the "wait" was still there, so I turned radio off right away thinking there must be some different code to enter to get rid of it.
So not knowing what i am telling you now, i would turn radio off and wait till the next time.
Bottom line leave your radio on while driving, and after an hour while you stop and go doing your chores with your car, the code input screen will come on.
The second you input your 4th digit radio goes on! Pretty satisfying.
Hope this helps...
Edited by Aharos
Hi, I hope someone can help. I just had my car fixed and they disconnected the battery and now radio was reset and i need a code. this is the info on the radio, Any help would be appreciated i tried everything to get the code
CDR-220/ Becker 1 type 4462 # X5030414   248/98
Thank you
Thank you
Try 4818
Thank you
Try 4818
Thank very much. It worked.
Yup replaced the battery in the wife's 2000 Boxster and guess what? Need the radio code. We've only had the car on the road a month. No manuals, stickers or anything. Any help would be appreciated.
4462 model
X5031065 is the serial.
Try 0430
That worked and donation made......Many thanks!!!!
I had a problem with my boxster fuse box and had to unhook it, When i hooked it back up the radio was locked. Bought the car used a month ago. Any possible help with code? or do i need to take it to dealer.
Becker 1
CDR-220
Type 4462
24/99
serial Y5038107
Thanks in advance for any help
Becker 1
CDR-220
Type 4462
24/99
serial Y5038107
Try 6541
Becker 1
CDR-220
Type 4462
24/99
serial Y5038107
Try 6541
Thank you I will try that first thing in the morning and let you know how it turns out
