Duh.   backup power came off when I was changing the battery, and I now need my radio code (can't find my original card..  hadn't needed it in 16 years)
The type is 4462
and the serial no.  y5041878
Thanks in advance..  this is an awesome thread for us guys my make mistakes ;)
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
The type is 4462
Try 0761
Try 0761
worked Thanks!!!
FYI:  not sure where you get the info from ,but if it's something you ever wanted to put into a program/site/auto-email, I can code it for you..
Just bought a 2000 911 and I can't get into the radio.  The Type is 4462 and the serial is either X5030190 or XS030190 (hard to tell with the old school LCD readout).
Thanks for your help!  Can't wait to get some tunes going
Try 8698
Try 8698
This is real magic!  Thanks!
Hello,
New, to me, car.  No radio code unfortunately.  Numbers are:   4462; Y504110
Followed the steps to get these, hopefully you have something for me!  Thanks!
It's a 2000 Boxster BTW
Try 0624
Thanks for the quick response, unfortunately those numbers don't work...and I tried it three times. So I'll be waiting for anymore combinations you may think will work. Thanks!
If you followed the instructions in the Lost Radio code FAQ and gave me the correct serial number then there is nothing more I can do for you.
If that is the serial number your radio reported then it is likely your radio has been repaired without following the Becker (the radio manufacturer's) procedures.
Well thanks Loren, I'm not sure about anything being repaired, as I bought the car a couple days ago, the dealer said they didn't have a code, I googled codes, and I found this site. So after the wait period is over, I will try to get those codes again to double check, but idk. Thanks though!
Alright...so the waiting period ended, tried again to no avail. Decided to double check instructions. I'm sorry, but the serial is actually Y5041100, with the 4462. I'm sorry I didn't put the second zero originally. I hope this is the reason the code you originally gave me isn't working :) thank you again! I have enjoyed very much the sound of the engine lately...
Well thanks again Loren, hat number worked! You provide a great service! :)
Hello!  I also need radio code...
99 boxster
Becker 1
ser. #: X5020527
type: 4462
48/98
CDP2065
Thank you!!!
Brandi
Hi, Battery has been dead and require radio code.
Typ: CDR 22
Model No: BE 6621
Serial No: 25009159
From sticker on radio
Typ: CDR 22
Model No: BE 6621
Serial No: 25009159
Sometimes the sticker is wrong - which is why we ask folks to use the procedure to display it on the radio (in the Lost Radio Code FAQ)
We'll see if your's is actually correct -- try 9765
Thanks so much for this service, I bought the radio with the manual but nowhere to be found was the code!
Model Becker CDR 220
Serial Number 15061752
Thanks again!
Thanks again!
Try 2484
Reinstalling the factory radio and missing the radio card.
Type: CDR 220
Model No: BE 4462
Serial No: Y5041349
(from sticker on radio)
Thanks in advance
Type: CDR 220
Model No: BE 4462
Serial No: Y5041349
Thanks in advance
We'll see if your's is actually correct -- try 0524
Hi, just got my first Boxster and the fuse had blown in the radio, replaced it and now need the code.
Type CR 220
Model BE 4362
Serial # Y5025342
Thanks in advance for your help.
Type CR 220
Model BE 4362
Serial # Y5025342
Try 3043
Hi, owned the car three weeks.  Came back from the shop and needs the radio code which I didn't get with the car.  Becker 1 CR 220 type 4362 SER (no alpha prefix) 15005073.
 2002 Carerra 2 Cab.
Many thanks.
Edited by BRP
