  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
I need help for my lost PIN code after battery change.
911 996 from 2003
Serial 35013134
Type 6632
Thanks!!
You obviously did not read the Lost Radio Code FAQ first...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Yes, I read too late. My Apologies!
Hi Loren, I do not have my radio code for my radio, it is a Becker  Type CDR 220, S/N X5024921, Model # BE 4462, hopefully you can help me.
Thank you.
Hi, I hope someone can help. I just had my 2001 boxster painted and they disconnected the battery and now I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated. I checked under the hood and my manual book. None is writen. Below is the radio info
Becker1
CR 220
TYPE 4362
24/99
SERIES: Y5024520
Hello I am need of my radio code for my 2000 boxster s. Becker radio 220 model 4462 serial y5039027.
thank you
Albert
Thank you.
Try 7354
Becker1
CR 220
TYPE 4362
24/99
SERIES: Y5024520
I have removed your duplicate posts - please post ONLY one time.
Try 5410
Hi Loren I've been looking everywhere for help and I'm so glad I've found your thread. I have a 2001 boxster base
Becker 1
Cdr-220
Type 4462
24/99
Serial:15088602
Becker 1
Cdr-220
Type 4462
24/99
Serial:15088602
Try 5810
99 c2 cab
4462
X5012930
Any ideas Loren?
Try 0987
That was it. I will right it down, but I will be disappointed with myself if I forget it. 0987 is almost as obvious and easy to remember as 1234. Thanks Loren
Hi, my battery died and i can not find my radio code.  2001 C2, CR-220 4362 Y5030347.
Thanks for your help
Try 0698
Thanks, that worked
thank you
Albert
