2001 986S original owner but can't find the card after a battery removal
CDR220
Type 4362
Serial # Y5030105
Any help much appreciated.
thanks.
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
CDR220
Type 4362
Serial # Y5030105
thanks.
Try 5424
You recently provided my with a code to use on my radio.  I have another issue, in that I cannot clear the "Wait" command. I have waited over night with no change, I then disconnected the battery hoping that the system would "re-boot". No luck.  Any advice?
I have a 1999 Porsche 911 carrera convertible. Installed engine battery was disconnected. I have a cdr-210 serial# w5022363. Model# be2282. It doesn't have the code anywhere. If you could help I've tried everything. Thank you
Try 6861
Help! Noob Porsche owner. Removed battery and didn't realize I needed a code for the radio. Here's the info:
CDR-220
4462
# Y5038779
24/99
GAL: 00
AUX ON (with 2 arrows)
CD CDP2081
In advance, thanks so much!
CDR-220
4462
# Y5038779
24/99
GAL: 00
CD CDP2081
Try 5209
I think  Im supposed to be here for a lost radio code
boxster s 2002
type 4462
ser 25017336
battery disconnect
no code with car
thanks in advance  Dino
boxster s 2002
type 4462
ser 25017336
battery disconnect
no code with car
Try 9030
Boxster 1999
Becker 1
cr-220
Type 4362
Serial X5010835
45/98
Boxster 1999
Becker 1
cr-220
Type 4362
Serial X5010835
45/98
Try 0507
4 hours ago, Loren said:
Try 9030
Thank you , will give it a try this afternoon and will make donation to the cause
Cheers  dc
Hi Loren,
I have a 1998 Boxster Base I'm preparing for a car show Sunday and I'm re-installing the factory radio for the event.
My factory radio is a CDR210, Model Number 2282, and Serial Number V5015324.
Thank you for your help with this!
Rudy
Hello there. My brother kindly bought and fitted for me a new battery this week but it reset the radio code. Porsche have been no help at all.
Cdr-22
Serial number x502 1233 type 4467
Thank you in advance.
Edited by Zingfharn
Typo
1 hour ago, Fangio1013 said:
Hi Loren,
Rudy
Try 2909
Cdr-22
Try 2427
I am hoping someone can help me.  I have a 2001 Porsche Boxster.  Like many on this forum, when I replaced the battery, the radio stopped working unless I punched in a 4 digit code.  I need help to figure out just what that code might be.  The radio is model CDR 220
Serial # y5052932
Type 4462
Thank you
Thank you, Loren. My code didn't work. I again followed the directions from FYI. Now I think I have have the correct info.
2000 Porsche boxster
CPR 2081
4462 15000612 24/99
Again thank you for your support.
  • Like 1
