45 minutes ago, Mike Watts said:
I have replaced battery in a newly purchased Porsche Boxster S reg VU03PNJ Radio is CDR22 can you help?
Serial number is 25008878 !!
Try 9585
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hello,  I have a 2000 Boxster S and lost the radio code when i changed batteries.
Radio info:  CR 220, Type 4462, SN Y5031094.
Thank you very much for your help.
Loren
Loren
Try 4146
27 minutes ago, burns334 said:
Hi, I need help with a radio code
SN BE2182T5001562
I see you did not read the Lost Radio Code - FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
35 minutes ago, Polydeuces said:
Hey there, are y'all still helping out with codes? Got a
CR-210
S/N: W5017886
Model #: 3297
thanks!
Try 2920
Hi-
Need assistance retrieving a radio code for '01 Boxster just out of the shop.
Type: 4462
Serial #: Y5054165
If this is the wrong forum or method, sorry in advance - please advise.
Thanks much,
-Eric
I need to retrieve the code for my radio.
Type: CDR-210
Model: R2896
Serial #: V5008564
Gaylon
1 hour ago, treadstone said:
Hi-
Type: 4462
Serial #: Y5054165
Thanks much,
-Eric
Try 4648
Type: CDR-210
Model: R2896
Serial #: V5008564
Gaylon
Try 1932
hello everyone, Just got my first Porsche and I must say I love the car. Did some work over winter time so off course I removed the battery( ya I know summer is almost over) I could the find the code to the radio so I hope someone can help me .cdr220, serial 15002247, 4462.  Thank very much.
Try 2349
