  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hello!
I have 2000 Carrera 4 CDR-220, and can't find the code.
Type : 4462
Serial : Y5035414
Please, let me know the code.
Kim.
7 hours ago, Bright Kim said:
Hello!
Type : 4462
Serial : Y5035414
Kim.
Try 7203
Can you help with my radio code please?  cdr-220 , type 4462,  ser# y5039835.  thanks in-advance. Really glad I found this site!!!!
Edited by Sammyc57
missing info
Try 5467
HELP PLEASE!! Boxster 2002 asking for a code:
BECKER
CDR220
Model: BE6625
Serial Number: 15005911
I appreciate any assistance. I have a message asking for a code.
THANK YOU
BECKER
CDR220
Model: BE6625
THANK YOU
Try 7084
Hi Loren,
Could you tell me the code?
I have a Becker 1
CDR 220
model 4462
Ser: 15001913
I got the serial number by holding the TP button until the unit beeps, and then scrolling through to the serial number. Is this the same as the number listed on the side of the unit? I would have to make some tools to get the radio out.
Robin.
6 hours ago, rdymond said:
Hi Loren,
I have a Becker 1
CDR 220
model 4462
Ser: 15001913
Robin.
Try 0941
1998 Boxster
CR-210
Model: R 1996
Serial: V5006198
If someone knows the code that would be incredible. I have been searching around to try similar codes but no luck :(.
Edited by stx5m
21 minutes ago, stx5m said:
1998 Boxster
CR-210
Model: R 1996
Serial: V5006198
Try 0948
Porsche 986 1999 CDR220 Becker 1
I have 2 problems:
  1. I changed battery so the radio needs the code
  2. the display is shot, so I cannot read the code from the display
VIN is WP0CA2987XU625061
time to ditch the radio? can I change the screen only?
I have 2 problems:
PLEASE read the Lost Radio Code FAQ and follow the procedure to get your serial number -- THEN post here.
32 minutes ago, Gene Thomas said:
Hi Loren,
2002 Boxster lost radio code when battery disconnected for engine replacement.
Becker  CDR-220
Type  4462
Ser # 250 10550
Try 0305
Hi Loren,
I greatly appreciate any help you can provide in getting the correct code for:
1999 C2
Becker CDR-220
Type: 4462
Seri: W5005600
1 minute ago, phins1372 said:
Hi Loren,
1999 C2
Becker CDR-220
Type: 4462
Seri: W5005600
Try 9454
