  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
6 minutes ago, Meirschwartz said:
Hi.
Need help with retrieving the code for my CCR-220.
model number BE6624
serial number 25006545
thanks in advance,
Meir.
Try 5230
Just purchased replacement radio on Ebay no code for my Boxster.  Becker CDR-220.
Serial Number 15064911.
Help with code?
Help with code?
Try 7274
3 hours ago, Roliver151 said:
CR 220
serial : Y5030551
You really did not need to post this three times.
From the site Guidelines/Rules that you agreed to when you registered here: "
  • Please post your messages in one forum only. Crossposting, double posting, triple posting, etc. are all a waste of time and valuable resources. If you post the same message in multiple times or in multiple forums, we will delete the ones we feel are inappropriate."
Try 0313
I have a 1999 Boxter
Radio:
CDR 220
Becker 1
Type 4462
Serial W5008146
Any ideas about the correct code to reset the radio?  My battery died, and the code I was given by the dealer based on the VIN is not the right code--probably a different radio was installed by the previous owner.
Thanks in advance for your ideas!
Radio:
CDR 220
Becker 1
Type 4462
Serial W5008146
Try 9437
Not sure if this is the right place to post as many of the postings seem very old, but...
Lost radio code, 2000 Porsche Boxster.
CDR 220
BECKER 1
Type 4462
Serial # X5025151
Thanks for any help.
CDR 220
BECKER 1
Type 4462
Serial # X5025151
Try 0762
27 minutes ago, Loren said:
Try 0762
Thank you for that immediate reply.  I had tried two codes last night and ended up getting the WAIT message.  Just now turned it on again and the WAIT message is still there after sitting overnight.  I disconnected the battery for a few minutes to see if that would reset it, but upon reconnecting the WAIT message is still there.  So now I have disconnected the battery and will wait an hour to check again, unless anyone has any other suggestions.  Many thanks, Paul
On ‎6‎/‎25‎/‎2007 at 7:07 AM, toons92 said:
Loren, You are the man, It looks like you have be the code whisper for over 10 yrs.  Well I have one more for you;
serial #15002961  model 4362  CDR 220   Thanks for your help....Bob
1 hour ago, EuroCarUS said:
Hi, I hope you can help me with a radio code.
CDR220
Serial # X5029398
Thanks so much. Any help is very appreciated.
Try 9650
