41 minutes ago, carlosmtg said:
Hi loren
I've got a 99 Boxter
The  serial number is X5032298
Type 4462
CDP2081
Could you please help me to get the code ?
Try 2757
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi I would really love some help getting my Radio Code.  I just bought 1999 Boxer and disconnected battery while painting and repairing the vehicle.
Becker
24/99
type 4462
serial 15061668
Thanks in advanced,
David
Becker
24/99
type 4462
serial 15061668
Thanks in advanced,
David
Try 8327
Hi Loren,
  Could I please get the code for the following:
  Becker MDR-32
  Model: BE 4967
  Serial: Y5016061
 Many thanks in advance!
Victor
Hello,
I have a CDR-220 and am looking for the code for 2002 911
Typ: CDR 220
Model No. : BE 6625
Serial No.: 15003677
Thanks in advance
Hi Loren - any help on solving this would be great please :
CDR-22
Type 4367
Ser: Y5022045
Its for a '99 C4 996
many thanks in advance
3 hours ago, JL911 said:
Hello,
Typ: CDR 220
Model No. : BE 6625
Thanks in advance
Try 5435
CDR-22
Type 4367
Ser: Y5022045
Try 9165
Sorry please ignore as I've just seen your FAQ. Thanks
Hi Loren I wonder if you can help with the code for a PCM1?
Becker
Model BE2580
Serial 15077826
Date 22/01
Thanks very much, Graham.
Edited by stonker
Wrong post
I too am one of the many that can't reset the radio. Also, I don't have or know the code. I have a 2002 996 TT. Stereo is a CDR-220. Can you help please?
Becker
Model BE2580
Serial 15077826
Date 22/01
You did not read the Lost radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
You need to read the Lost radio Code FAQ... then follow the procedure to get your serial number... THEN post it here.
Hi L-
First, I want to thank you for this service. You are great to do this!
I just got my latest CDR-220 off eBay and looking for code.
Serial # W5011451
C
1 hour ago, lj1 said:
Hi L-
Serial # W5011451
C
How many radios do you have?
Perhaps you should consider Contributing to this site?
Try 4925
Try 4925
I will! This code however did not work. Thanks again.
Did you use the procedure in the Lost Radio Code FAQ to get your serial number?
If not, then please do so and re-post the correct serial number.
On 07/01/2017 at 0:59 AM, Loren said:
Try 9165
Fantastic- that worked perfectly!!! Thanks so much for your help Loren!!
Hi L-
Yes, followed FAQ and serial number comes from the label on side of radio as well as the display.
Serial # W5011451
Any other thoughts?
So sorry to bother Loren, I too need your code help...
2002 911 TT
CDR-220
model # 4462
serial # 25016505
vin# WP0AB29922S687369
Thanks for any help you can offer.
Ken
2 hours ago, lj1 said:
Hi L-
Serial # W5011451
Any other thoughts?
Try this one 4924
2002 911 TT
CDR-220
model # 4462
serial # 25016505
Ken
Try 2879
