  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Another request for a missing radio code.  Radio info is as follows:
  • CD-2 Compact Disc Radio (Alpine or ??)
  • 54A90727F02-A (# on sticker on bottom of radio)
  • PO CD-2 M 06 18154 (SN etched on back of radio)
  •             B 1  06 18154 C (# etched below SN on back of radio)
Really appreciate your assistance!
SK
Hi please can you help!
Radio requires code after battery change.
I have a 1999 996 with
Becker CDR-22
ser #W5006347
SK
If you read the Lost Radio Code FAQ before posting here you would see what radios are supported here.
Becker CDR-22
ser #W5006347
Try 2893
2 minutes ago, JDawkins said:
need a 4 digit radio code
Becker CDR 23
model be 6612 serial 25026120
2003 boxster standard
vin wpoca29893 u622978
You did not read the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
2 hours ago, MarkM2412 said:
I hope youcan help.
1998 Boxster
CDR-220
Becker 1
type 4467
Serial Y5026264
Thank you very much.
Try 5060
Please could supply the code for my radio
It's a Becker 1 type 4667
Serial number 15000798
Sent from my iPad using Tapatalk
Try 7626
Try 7626
I will have a go thanks for your quick response !
Good news the number worked a treat ! Thank you very much.
35 minutes ago, flautoboxster said:
Need code help. 99 boxster Becker 220 CD player serial number is X5017498
Really?  I gave that to you last year. Perhaps you should write it down this time.
Hi Loren
I have a 996 4s with a PCM 1. SN: PO8150120975/01. Just changed the battery and need the two codes. Do you think it's possible?
/Carl
