  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi, I'm new here. Is this topic still relevent?
I need code to My navi (996 C2 -98)
On the back i can see this:
siemens
MLFB: 5wk 78000A
serial nr: PO8000092872/03
Best regards
David
siemens
MLFB: 5wk 78000A
Best regards
David
You did not read the Lost Radio Code FAQ - read this first did you?
If you had you would have seen this: "Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
26 minutes ago, lfindlay2019 said:
Hi Loren,
Really hoping you can help me out;
Becker 1
Serial - w5005085
02/99
CD - CDP2065
Type - 4467
Thanks in advance!
Try 9419
Hi yet another battery disconnect thus not allowing me any proper tunage, Ive got a CDR-220 and after holding TP for 10 seconds ive got  4462 and 15005357,
The number it gave me looks different than the other numbers on the forum, any help would be greatly apprecieted, patiently WAIT ing lol
Try 3163
1 hour ago, david mathews said:
Changed the battery in my 2000 boxster S and need a radio code.  cdr 220 serial # x5038520.  Any help greatly appreciated.
Try 1570
