  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
12 hours ago, Scott Mathison said:
Hey!
I had a dead battery and can't find my code to get my radio to work again.
I checked my Becker CDR220 and the serial number is W5003111 .  Any help with my code would be awesome!
Thank you!
Scott
Try 0318
New to me 1998 Boxster 986
Radio is a CDR-210
Model # R3297
Serial #  W502 1848
If you would be so kind as helping me with the code, I would appreciate it.
Radio is a CDR-210
Model # R3297
Serial #  W502 1848
Try 6836
   18 hours ago,  Scott Mathison said:
Hey!
Thank you!
Scott
Try 0318
Thank you!!!!  Saved Me!!!
Scott
3 hours ago, Ford's 00 986 said:
I have a 00 986 with serial # W5010040. Please send me the radii code to unlock. Thanks! Ford
What is the model on the front of the radio? (i.e. CDR-220, CDR-22, etc.)
I was sure the code was written in the Porsche radio booklet... I was wrong but didn't realize until the new battery was in !!
CR-210
Model BE2162
Serial: S1000438
Thanks in advance for reversing my stupidity......
Try 5278
I was able to validate the following info after following the instructions to pull the radio version and serial number:
Becker
R 1996
V5006551
please let me know if you could kindly provide the radio code as the one previously provided did not work.
Many thanks
Sent from my SM-G935T using Tapatalk
Becker
R 1996
V5006551
Many thanks
If the code I gave does not work then it is likely that your radio has been repaired by a 3rd party (rather than Becker).
You will need to contact Becker North America to get this resolved.
thank you Loren. unfortunately I have no clue who repaired ut and when. Thank you for trying!!!!
Would u be able to confirm that code 5278 should be the code to unlock it?
Yes, but radio components have been changed and your code could be anything now.
Got it! thank you
Hello Loren....
I wasn't sure if one of the replies today was for my post last night.
Thanks in advance ... Mark, Southern California
Ps: Thanks for being such a great resource to so many with radio issues ....
CR-210
Model BE2162
Serial: S1000438
Try 5010
  • Like 1
hi at all members
i have buy 996 year 2001
end i have lost code for problem low battery end porsche no have !
my Pcm is news year 2016 , i no find my 2 code unlook
please is possible have code ? my number complete is on Photos
tank's in advance
8 hours ago, uomoconle00 said:
hi at all members
tank's in advance
Sorry, you did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
5 hours ago, Dan Peters said:
Hi - can someone please help with my lost code. It's a CDR-22
Serial: 25010001
24/99
Type 4467
Appreciate the help.
Try 0108
