  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
New to me 99 boxster,   I need my radio code.
cdr 220
type 4462
ser.  X501852348    98/00
any help appreciated.  Thanks
cdr 220
type 4462
Try 6741
Hello I have a 99 boxster which i need a radio code,dealer was not helpful:
Becker 1
CDR-220
Type: 4462
sn: WS008329
vin: WP0CA2985XU633014
48/98
Thank you.
Becker 1
CDR-220
Type: 4462
sn: WS008329
48/98
Thank you.
Try 8727
1 minute ago, Charlie Arborvilla said:
Howdy! I changed the battery on my new-to-me 2002 Boxster, and I need the radio code.
CDR-220
Type 4462
Serial: 15002883
Thank you very much!
Try 0521
Let me try again.    this time with hopefully correct serial number
99 boxster
CDR-220
Type 4462
Serial:   X5018523
48/98
GAL: 00
Thanks again.
3 hours ago, Nemoporsche said:
unfortunately 8727 did not work :/
Did you follow the procedure in the Lost Radio Code FAQ?
If you did not, then please do so and re-post your correct serial number.
If you try again and get the same serial number then chances are your radio was repaired by someone other than Becker. And, the serial number change is unknown. If that is the case then you will need to contact Becker.
99 boxster
CDR-220
Type 4462
Serial:   X5018523
48/98
GAL: 00
Thanks again.
Try 1594
Purchased 2000 996 that had been sitting for 10 years with 19k miles. No radio code on sticker under the hood. Can you please help with a code?  Thanks!!!
CDR-220
MN#  BE4462
SN#  X5033272
CDR-220
MN#  BE4462
SN#  X5033272
Try 2359
8 minutes ago, Nemoporsche said:
Did all the procedures correctly, any other codes?
