Sorry Loren I cant seem to get it if this is wrong I will not bother you again, my apologies.
2001 Carrera C2 radio CR220
Becker 1
type 4362
ser number X5019877
47/98
Try 9387
or
9385
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi. I bought a CDR-220 and a CDR23 from a dismantler. I know that there's a way to decode the CDR-220 code, and I know that the CDR23 reads the code from the DME, but I have a 1997 986 Boxster which DME does not support this function. Can someone please provide me with the CDR-220 code and a way to turn off the CDR23 "PROTECT" function and disable the code circuit? Here is the information for both units:
CDR23:
Model No.: BE 6612
Serial No.: 45058572
Date of manufacture: 03/04
CDR-220:
Model No.: BE 4462
Serial No. 15075622
Date of manufacture: 13/01
Thanks in advance
CDR23:
Model No.: BE 6612
CDR-220:
Model No.: BE 4462
Serial No. 15075622
Thanks in advance
You can not use the CDR-23 in a non-MOST (fiber optic) car. I do not know of any way to "bypass" the security code.
For your CDR-220
Try 9618
or
9616
Becker 1
type 4362
ser number X5019877
47/98
Try 9387
or
9385
First code works, thank you , donation just processed.
Becker 1
type 4362
ser number X5019877
47/98
Try 9387
or
9385
Thank you for your donation!
Hi. I have a 2000 Porsche 911 Carrera.
I need the radio code for my radio.
Serial number is X5018878.
Model number BE4462.
Type CDR220
Try 9585
or
9583
Type CDR220
Try 9585
or
9583
Thanks ALOT!! The first code worked!!!!
Hi Loren,
Same problem, battery died on my 1999 Boxster, no radio code.
CDR 210
R 3297
W5022883
Thanks so much for your assistance. It is greatly appreciated.
John
Hi Loren,
CDR 210
R 3297
W5022883
John
Try 0509
or
0507
Hello, could you kindly provide me with my radio code?
Here is the information on my car/radio:
2000 Boxster S
Part 996.645.126.00
Typ: CDR 220
Model-No.: Be 4462
Serial-No.: X5033238
Thank you very much in advance!
2000 Boxster S
Part 996.645.126.00
Typ: CDR 220
Model-No.: Be 4462
Try 8502
or
8500
Thank you Loren! B)
2000 Boxster S
Part 996.645.126.00
Typ: CDR 220
Model-No.: Be 4462
Try 8502
or
8500
Edited by pwrattorney
Hello,
My battery went dead on my 2000 Boxter and I need the radio code. If someone could help, I would greatly appreciate it.
Radio: CDR220
Type: 4462
S/N: X5033245
Many thanks,
Joe
Hello,
Radio: CDR220
Type: 4462
S/N: X5033245
Many thanks,
Joe
Try 8558
or
8556
Thank you so much!
Hello,
Radio: CDR220
Type: 4462
S/N: X5033245
Many thanks,
Joe
Try 8558
or
8556
Ok, I did the all time bone head move and threw out the card that my radio code was written on by accident. No, not the original gray plastic card, I had written it on the back of a business card . . . .
It is a CDR220, SN Y5047779
I believe that it was something like 4869 . . .
any help is greatly appreciated!
Frank
Frank
Try 4895
or
4893
Hi Loren I hope I am doing this right this time.
Boxter 2001
Radio CDR 220
Model BE 4462
Ser # Y5053060
Thank you
Try 9093
or
9091
Hi Loren tried both codes they did not work used 9095 and that worked.
Thank you for your patience and help
