51 minutes ago, Ryanabab said:
Hi Loren,
I’m getting my parents 2001 turbo ready for them to enjoy and their radio is asking for the code. May I have this code?
2001 Turbo
Becker 1
cdr220
type 4462
SN 15085164
Thank you in advance!
Try 0876
Please consider a donation to keep this site running - thank you.
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
16 minutes ago, Steve Faltermeier said:
have a 2002 911
Becker cdr-220
serial number 25015709
looking for a radio code-
Anyone help!
Thank you!!
Try 4715
Hi Loren,
I Can help me find a code for the 16-bit PCM Navigation Unit
MLFB: 5WK76026
Serial No: P0221024P9467
Date: 31217
996.642.122.12.EWD
Thank you
3 hours ago, fab768 said:
Hi Loren,
MLFB: 5WK76026
Date: 31217
996.642.122.12.EWD
Thank you
You didn't read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hi...same thing happened to me as to most, replaced the battery and the stereo is locked and I can't find the code in any of my manuals.
Model/type - 4362
Serial no - y5024231
Any help would be greatly appreciated...
Model/type - 4362
Try 8760
51 minutes ago, kerry986 said:
Lost code...
Type CDR23
Model #BE 6612
Serial #35044637
Thank you Loren!
CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DMEand can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
Thanks Loren, got a little ahead of myself. Guess that’s why the FAQ says “Read this first”!
Kerry
Hey Loren,
  I thought I'd cut to the chance and donate ~before~ I asked for the code.:clapping:
Total newbie here.
Bought my first Porsche 2 days ago. A 2000 Boxster S.
Looks like I need to get the radio code after hooking up the battery.
Becker cdr-220
Becker1
type 4462
serial number Y5041068
1 hour ago, Ben Bullock said:
Hey Loren,
Total newbie here.
Becker cdr-220
Becker1
type 4462
Try 0354
I would greatly appreciate your help with my missing code! Thank you!
Type 4462
X5013335
CDR-220
Edited by bob v
I need some help with my 1998 Carrera used with a working Becker Radio CR 210.
Battery was disconnected for painting and now I'm stuck.  I've read through some of the posts and tried a few suggested codes with no success.
When I bought the car it came with a card:
IDENT-KARTE Becker Automotive systems
CDC-3 V1018228
Nothing named "code card".
Any help will be appreciated.
First I apologize for previously posting before reading the FAQ - first time user but should have known better.
Looking to recover use of the radio after disconnecting the battery.
1998 Carrera
Becker CR 210
CDC-3 V1018228
7 hours ago, Jay hughes said:
Hi, can anyone help me, I've lost the code for my boxster radio :(
Type 4467
serial Y5025826
thanks in advance
jay
Try 2820
  • Thanks 1
Type 4462
X5013335
CDR-220
Try 6547
1998 Carrera
Becker CR 210
CDC-3 V1018228
Try 1312
