On 4/30/2018 at 5:55 AM, Loren said:
You did not read the
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hi Loren. Sorry about that, i think i read that bit after i posted.
Apparently retrieving the code from a PCM1 is no trivial task. After paying the dealer a visit, they provided me with the codes that corresponded to the VIN, which didn't work. So then they suggested calling Porsche NA (1-800-Porsche) which they turned me back around and told me to talk to the dealer. Called dealer again and got to emailing with a tech. He tried to email porsche NA directly with my radio serial number. Porsche NA came back and told him that they needed more info, so now i have to physically drop the car off at the service center so the tech can hook the radio up to their diagnostic testing hardware and pull more information from it.
The one thing the tech did tell me is that, if you have a PCM and you take it to your nearest Porsche dealer, and they don't know what to do, he said to tell them the following:
Submit a PTEC - TLAR for filing issues, and PQIS job and run VAL attached to PTEC request.
Im not sure what any of the above means but for those of you who are struggling with your dealer in retrieving a PCM1 code, tell them to try that.
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
16 minutes ago, Sebri said:
Yes i did i used the 8 and 0 simultaneously and got my Sireal NO
Then it is likely that your radio has been repaired by someone other than Becker. Doing so changes the serial number and without them updating it properly I do not know any way to get the "unknown" serial number. Sorry.
Hello,
First off I would like to thank you for providing this service... you are lifesavers.
2000 Boxster
CDP2051
24/99
Ser: 25010876
Type: 4462
2 minutes ago, randykieling said:
Hello,
2000 Boxster
CDP2051
24/99
Ser: 25010876
Type: 4462
Try 0835
wow!
you are on the ball. I figured it would take a while so I posted from work.
I will try that code as soon as I get off work.
thank you very much
Randy
any help would be greatly appreciated.  Just bought an old 1999 porsche with a dead battery and no radio code provided.
cdr 220
4463
W5012352
thanks in advance to anyone that can provide a good code.
My battery in my 2001 Boxster went dead.  Now I need the code to get the radio working again.
Radio: CDR 220
Type : 4462
S#:  Y5052581
cdr 220
4463
W5012352
Try 6873
Radio: CDR 220
Type : 4462
S#:  Y5052581
Try 0173
Help hugely appreciated. Dead battery = no radio
CR 22
Serial X5020324
Type 4367
Edited by T4toria
Hello Loren,
Pls help me obtaining the radio code for:
1999 Porsche Boxter
Radio Type: 4462
SN: 15075111
24/99
Gal: 00
CD: CDP 2081
Thank you so much.
13 minutes ago, E Phuong Ho said:
Hello Loren,
1999 Porsche Boxter
Radio Type: 4462
SN: 15075111
24/99
Gal: 00
CD: CDP 2081
Thank you so much.
Try 9627
2002 Porsche Boxster
I have a CDR 220
Ser# 15002270
Becker type 4462
Need the radio code please.  After a really dead battery.
Thank you in advance.
Edited by Acha n.v ak
I have a CDR 220
Ser# 15002270
Becker type 4462
Try 2543
  • Thanks 1
