  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
1 hour ago, tacdriver904 said:
Hey Loren,
Your help is greatly appreciated...
1998 Boxster
CDR 210
Model: BE 2282
SN: W5018439
Thank you very much for helping all of us out!
Try 3753
12 hours ago, Loren said:
What is the model number on the front of your radio?
I just took the head unit out, and found the model and serial number: BE 2580 - 15085884
Can anyone please help to generate the 4 digit code? thank you and much appreciated.
Did you read the Lost Radio Code FAQ?
That is a PCM unit.
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
  • Like 1
That is a PCM unit.
thanks Loren, guess I have to spend $200 for just the 2 codes at the authorized garage.
Can you help with my C4 2001 radio code?
I have a cdr 220 serial number 15076414
Thank you in advance!
Rusty
Rusty
Try 7013
13 hours ago, Loren said:
Did you follow the procedure in the Lost Radio Code FAQ to get the correct serial number?
Hi Loren yes I pushed TP for 10 seconds and Becker appeared and I turned smoothly the right knob till I get the serial nbr which I sent here previously
than I tried 0519 but it didn't work
Any suggestion or nbr pls?
If the number I gave you did not work then it is likely that your radio has been repaired by a third party (not Becker) and the serial number was changed.
I am sorry but in this case, I can not help you - only Becker can correct the issue.
Hi, would you happen to have the radio code for my:
1999 911
Becker
Type CDR 220
Model No BE 4462
Serial No W5009586
*4462KF0W5009586*
Thank you very much.
Alice
1999 911
Becker
Type CDR 220
Model No BE 4462
Serial No W5009586
*4462KF0W5009586*
Alice
Try 1908
