  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
2 minutes ago, Tim Burton said:
Hi I just bought a new CDR220 and would really appreciate it if you could lookup the code?
CDR220 4462
 Serial x5038385
Try 4321
Loren:  Disconnected battery on my newly acquired 2000 996 cabriolet to work on windshield washer reservoir and my radio, a CR-220 (Becker), thinks I stole it. Serial no. Y5021121. Would you be so kind as to provide the magic security code (I’ve looked everywhere).  Thanks in advance. John
Try 4362
12 minutes ago, Maverickyz250f said:
Hello,
Need a radio code for a 2002 Porsche Boxster S
Cr-220 model
serial # 15004453
let me know if there's any other info that would help.
Try 1290
Loren:
Thanks for the code, but it didn’t work. After “code” appeared with numbers above the lower buttons I pressed 43 and the stars went out, but when I presses 6 it did not, then one star appeared and I pressed 2 and it went out, but the radio went to “wait,” where it remains. Is it mad at me?
John
2 hours ago, John Churchill said:
Loren:
John
If it did not work then try again - please read the Lost Radio Code FAQ for the "Wait" message.
If it still does not work then it is likely that the radio was repaired by a 3rd party and the serial number was not reset properly. In those cases Becker may be able to help (for a price).
Loren:
Thanks again for trying. I pressed tp again and slowly turned the tuning knob and 4362 appeared after “TYPE,” then the serial no. Y5021121, then CDW RESET. Not sure to do to reset. Time to contact Becker?
John
Hi There,
Happened to stumble upon this forum and hoping that someone would be able to help to retrieve the code for my newly acquired Boxster.
Becker CDR 220
type BE 4462
serial # X5028780
Thanks in Advance!
2 hours ago, rexg said:
Hi There,
Becker CDR 220
type BE 4462
serial # X5028780
Thanks in Advance!
Try 5217
